Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 125
Thread: Best place to buy Warn Hi mount parts?
    175 Post(s)
    Thanks for the tips. Amazon US will be blocking Australian buyers as of next month.
    So you have 5 days to place your order
  2. The Following User Says Thank You to Hodge For This Useful Post:
    Avo (28th June 2018)
    462 Post(s)
    Yeah i thought about rushing an order in. I need to sort out the ghost water leak first.
  5. #13
    472 Post(s)
    ....MB's got the Mahle / Iskra motor. He got his through the 4WD shed in Bayswater, could use them for motor and parts I used roadrunner also patrolapart is another option......
    Beast of a motor, originally recommended kindly by MudRunnerTD. Daz’s mate Phil there reckons he can run at least twice the comp challenges on only one compared to the Bow 2 and eats the Warn 6hp of same size for breakfast. @matfew Navi (industrial sparky) can explain the Iskra/Mahle superior hauling/no bog down sound he loves so much better than my nuffy understanding can. “It just keeps cranking up and up and....” :-)
  6. #14
    462 Post(s)
    Heres the winch...
    and the motor...
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Hodge (25th June 2018), MB (25th June 2018)
  8. #15
    472 Post(s)
    Sexy they are mate!
    3.0T++ Patrol beasts they need Daz’s & Phil’s help ;-)
    Totally fried/shredded mine in its past life on 1.0T less minimum Land Crabs. Big GU trucks we’ve got need best Giggle inside bits also;-)
    Let us not forget, these higher speed wiches (stock) are only an 8,000lb jobbie :-)
  9. The Following User Says Thank You to MB For This Useful Post:
    mudski (25th June 2018)
  10. #16
    462 Post(s)
    Amazon for parts. Warn USA for the sticker kit
    Cant I just get the sticker kit in OZ? Or are they not available here?
    MB (25th June 2018)
  12. #17
    472 Post(s)
    Have you scored Warn-USA advertising commissions you lucky duck :-)
  13. #18
    462 Post(s)
    Thought I might quickly get a few things off Amazon while before they close it off to us. I wasn't going to but, I am now. Lol. Without knowing what is needed, apart from the lower house service kit and the brake service kit. What else should be replaced regardless? I may not have time to strip it down fully by the weekend.
  14. #19
    192 Post(s)
    Not sure where to get them from if possible over here. Hopefully get one for free, they used to. . .
  15. #20
    462 Post(s)
    Free?! I like the sound of that!
