Page 363 of 567 FirstFirst ... 263313353361362363364365373413463 ... LastLast
Results 3,621 to 3,630 of 5662
  1. #3621
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Trans oil temp gauge , buying was the easy bit , fitting is something I'm not looking forward to .
    Might have to trawl the forum for some ideas .
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I've done mine. Where the cooler pipes run from the trans to the radiator, there is a point where they are joined with a rubber hose. i just got a tee piece from enzed and tapped it to screw the sensor into, then fitted it in the line. Best done from under the car. Can't really put a pic up as i can't take a picture without removing half the engine bay.
  4. The Following User Says Thank You to 4bye4 For This Useful Post:
    GQtdauto (11th April 2017)
  5. #3623
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Haven't really been underneath the bus for a while but know it's a hard line to the radiator , but I'm putting in a transcooler anyway.
    I have heard that drilling and tapping the banjo bolt where the oil comes out is the best spot but will keep that option in mind .
  6. #3624
    Jul 2015
    Camden NSW
    6 Post(s)
    Some more tie downs. Currently $39 at Bunnings. Good value.
  7. The Following User Says Thank You to bazzaboy For This Useful Post:
    threedogs (11th April 2017)
  8. #3625
    Quote Originally Posted by bazzaboy View Post
    much safer than the old Ocky strap, which imo should be banned.
    Gee they are rated very high which is good as well
  9. #3626
    175 Post(s)
    Technically bought my self a 3 month forgotten LED bar... Thanks Supa Center!
    Trial fit to roughly where I'd like to mount it. Bolts will go from the side central pillars off the bar.
  10. The Following User Says Thank You to Hodge For This Useful Post:
    GQtdauto (12th April 2017)
  11. #3627
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Those zip ties will hold for good trust me !
  12. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    DX grunt (12th April 2017), Hodge (12th April 2017)
  13. #3628
    .......... TPC's Avatar
    63 Post(s)
    Got some new boots fitted to the Patrol.
    Stuck with the BFG AT's.
  14. The Following 5 Users Say Thank You to TPC For This Useful Post:
    BigRAWesty (13th April 2017), DX grunt (12th April 2017), Hodge (12th April 2017), Rossco (12th April 2017), Winnie (12th April 2017)
  15. #3629
    175 Post(s)
    Probably better then the small brackets they sent me with the bar...
  16. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    GQtdauto (12th April 2017), threedogs (13th April 2017)
  17. #3630
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Took the kids to see the dinosaur show in Perth and on the way back decided to take a detour and head down Telephone Lane in Baldivis for a quick wheel.
    While it was pretty easy going man that place is real chopped up now. Been years since I been down it. It was dry all the way through apart from 1 fairly decent looking long mud hole which 2 guys in tritons was having trouble with. Didnt bother with it myself as I didnt haveany recovery gear on me.
    On a side note I definitely need to put in a lift and bigger boots as soon as I can. Dragging my arse and diffs everywhere
    2002 GUIII Ti 4.8
    Details here
