Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: Recommend Cordless Impact Drill
  1. #31
    Thanks for all the replies folks.
    I think I'll get one of those eBay wrenchs, I can't see how I can go wrong for the price. Later on I'll probably look at the 18v range of stuff, I don't mind a bit of gardening so that all looks like a really good idea.
    Thanks again everyone.
    I use a Makita 18V hedge trimmer around the house and then a leaf blower to tidy up afterwards. Only have a few hedges but it does a good job. Options are endless!
    MB (7th February 2018)
    472 Post(s)
    Ryobi One+ 3speed impact wrench, quite a handy series at a reasonable price
    https://www.bunnings.com.au/our-rang...s/r/ryobi-one-
    Quickly checked em out today at Bunnings mate, very reasonable prices too I agree. Some 60+ tools in the 18v range they reckon not including the gardening bigger stuff either.
    http://www.ryobi.com.au/power-tools/...amily/one-plus
    The little $99 27Nm 3/8” ratchet wrench skin looked pretty cool too!
    Clunk (8th February 2018)
  6. #33
    Unafordable
    4 Post(s)
    Get "Blue" professional Bosch series tools especially this kit as it has everything you will ever need either at home or in the bush.
    2 piece 18v brushless 6 ah combo kit
    The 1/4 impact driver ( Impact Driver GDX18VECBB) will undo wheel nuts on Patrol (133 Nm) and bonus is that it has inner 1/4 driver with outer 3/8 drive on it.
    So you can use 1/4 bits and get 3/8 drive impact sockets for it as well. Absolute gem!
    They also throw in a bonus angle grinder with it so getting 3 cordless tools!
    My workmate uses this thing at work and can't kill it. It will undo trucks chassis M16 bolts,
    The drill is the same it just keeps going no matter what abuse.....
    I only wish I knew when I was getting Milwaukee 3/8 impact gun/ratchet combo .....
    Note: Don't ever rattle wheel nuts back in, especially alloy wheels.....
    Regards
  7. The Following User Says Thank You to Rumcajs For This Useful Post:
  8. #34
    472 Post(s)
    They are very good too I agree mate, recently worked with some Bulgarian’s that swore by Bosch Blue daily.
    Out of honest interest though, is it ok if I rattle lightly back on my wheel nuts before final torque up/check? Steelies not Alloy I run always. Cheers!
  9. #35
    109 Post(s)
    FWIW I hand thread mine back on, then rattle one or two ugga duggas around the pattern, then torque the rest up around the pattern. Can't see a problem with that. I don't just ugga dugga right up like tyre shops.
  10. The Following User Says Thank You to Plasnart For This Useful Post:
  11. #36
    472 Post(s)
    Cheers Plassy, I’ve always hand thread started and then run them up lightly but fast. Never in a circle I was tought, always incrementally opposite each shot. Finally torque up same same again. Is this correct, I hope?
  12. #37
    109 Post(s)
    Sounds same as me. Don't think you have to be a rocket surgeon to know to fix them up as opposite as possible and to spec torque. Light spin up with impact wrench once threaded, then finish with torque wrench. I actually repeat circuit after first torque up just to make sure nothing moved.
  13. The Following User Says Thank You to Plasnart For This Useful Post:
  14. #38
    109 Post(s)
    Being a Makita slut this is my choice of impact wrench, however seeing some of these cheaper units in this thread I'm thinking why spend the $$ when it's an occasional tool? Different batteries, chargers everywhere, etc gives me the sh!ts so I'll just stick to what I trust. Japanese only though, Makita make different stuff in different countries. Cheaper Makitas of same tool are made in different countries.
  15. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (8th February 2018)
  16. #39
    Unafordable
    4 Post(s)
    As long as you start by hand and then only drive them in sequentially until they touch/light torque you'll be fine. Steelies are more forgiving than alloys.
    Regards.
  17. The Following User Says Thank You to Rumcajs For This Useful Post:
  18. #40
    472 Post(s)
    Bugger, going to be late for work today :-( Only 2 minutes though with this beast of a demo blade onboard:-)
  19. The Following 4 Users Say Thank You to MB For This Useful Post:
    AB (8th February 2018), MudRunnerTD (8th February 2018), Plasnart (8th February 2018), Rossco (8th February 2018)
