Page 993 of 1049 FirstFirst ... 49389394398399199299399499510031043 ... LastLast
Results 9,921 to 9,930 of 10488
  1. #9921
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Truckus and I had a chat about him being a bit of a Classified Under Nissan Truck today. He has decided to develop a dicky door latch mechanism, right when I needed to load a couple of cartoons of coldies and some scotches in. So some tinkering to do...have posted the issue elsewhere.
    But that meant I had to go around the other side as was too lazy to unlatch all the rear barn door rigs.
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  2. The Following 2 Users Say Thank You to Truckus For This Useful Post:
    MB (15th February 2021), Plasnart (15th February 2021)
    109 Post(s)
    Quote Originally Posted by Truckus View Post
    Love a good cartoon!
  5. The Following User Says Thank You to Plasnart For This Useful Post:
  6. #9923
    Feb 2021
    Central Coast NSW
    Damn..I hate predictive txt...ROFL..must have been this brand...
  7. The Following 2 Users Say Thank You to Truckus For This Useful Post:
  8. #9924
    472 Post(s)
    Had another quick play with the new GQ gullwing emergency oil carting sliders this afternoon:
    Oil baffle sort of, most importantly a strengthening rib inside for the main 150x50x3mm RHS slider tank.
  9. The Following 5 Users Say Thank You to MB For This Useful Post:
    10G (17th February 2021), Cremulator (16th February 2021), jay see (19th February 2021), mudnut (16th February 2021), Plasnart (16th February 2021)
  10. #9925
    Ever since the rebuild, the lifters have been noisy. Swapped the machined lifter carriers/cradles out. This carrier is 20 thou thinner, than standard so the hydraulic lifter are able to cope with the new profile of the ground cam and the heavy valve springs. So much quieter now.
  11. The Following 5 Users Say Thank You to mudnut For This Useful Post:
    10G (17th February 2021), jay see (19th February 2021), MB (16th February 2021), MudRunnerTD (16th February 2021), mudski (16th February 2021)
  12. #9926
    461 Post(s)
    Put half a shed junk checker plate box to use as a heat shield from the pissy little Safari turbo:
    Baby compressor and new catch can fitted up pretty well:
    Will have to play around a bit more with hosing for both contraptions during the week before taking the plunge into drilling holes through the new airbox
    Pretty happy with the catch can drain, should be able to rest a little empty Berocca bottle on the coil tower whilst waiting:
    Mr MB were you told that catch can is only rated for engines up to 100kw. Not sure what the Golden oldie has had done to her but you’d be pushing the boundaries with it I’m guessing.
  14. #9927
    461 Post(s)
    Ever since the rebuild, the lifters have been noisy. Swapped the machined lifter carriers/cradles out. This carrier is 20 thinner, than standard so the hydraulic lifter are able to cope with the new profile of the ground cam and the heavy valve springs. So much quieter now.
    I think you must be the RB king mate . Is there anything you don’t know about these engines? Stupid question as if you didn’t know something you would surely find out.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #9928
    472 Post(s)
    I could be wrong Brother Mark Mate but pretty sure Youtubey educated me they were rated at 230Lm
  17. #9929
    Thanks, Mudski, but I can't take credit for this. The engine builder thought of it, I just swapped out the components.
  18. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MB (16th February 2021), mudski (16th February 2021)
  19. #9930
    461 Post(s)
    What did you do to your Patrol today!
    Not sure what that equates too for a TD, but the that can is the Provent 100. 100 meaning for engines up to 100kw.
    Sorta off topic but I sold 8 Parker units to a customer late last year. Each genset required two cans capable say to the equivalent of a 400kw engine. They were nearly 4grand each. These things were massive too. Had to fly them in from the US as well.
    I get to see and sell some funky stuff from time to time.
  20. The Following User Says Thank You to mudski For This Useful Post:
