6th May 2016, 06:27 PM
#11
Rotaredom
From my old man
https://www.efihardware.com/
https://www.youtube.com/watch?v=rKr6NM2YrtU
Nissan Patrol TB42 TB45 Series Engine Fuel Rail Upgrade for High Performance Applications
EFI HARDWARE CONTACT DETAILS
ADDRESS: 7 Monomeeth Drive Mitcham, Victoria, 3132,
Australia
EMAIL:info@efihardware.com
PHONE AUS: (03) 9873-5400
PHONE INT: +61 3 9873-5400
FAX AUS: (03) 9873-5955
FAX INT: +61 3 9873-5955
BUSINESS HOURS:
Mon-Fri 8.00AM - 5.30PM
We are closed on Saturdays, Sundays & Public Holidays.
The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
6th May 2016 06:27 PM
6th May 2016, 06:50 PM
#12
put it this way on 4psi with a shit 2.5 exhaust with restrictive mufflers and a wastegate that was blowing open it made a lazy 100kw at the wheels, which was a great improvement over stock, the exhaust helped a bit more and fixing the wastegates preload helped alot getting full boost by 1200 rpm pulls better than a diesel down low but have some major boost creep which needs an external wastegate to get under control. im still half considering fitting an external wastegate, intercooler and retuning to run on 10-12psi but in reality its only gonna make about 170-180kw when the stroker makes about 220-230kw with great bottom end torque
also be very wary of ebay manifolds as they have a bad rep for warping and cracking
6th May 2016, 07:33 PM
#13
Rotaredom
Off topic Irish but when you quoted me in your post were you on a mobile using tapa talk?
6th May 2016, 08:23 PM
#14
Patrol Guru
Thanks for the info guys, much appreciated :-)
Yeah, haveheard the same about the ebay manifolds, will keep an eye on it, and will probably fab one up if it looks like it's gonna fall apart.
Niss, no mate, I'm just on the regular forum page, using chrome on my HTC M8.
The Following User Says Thank You to Irish For This Useful Post:
NissanGQ4.2 (6th May 2016)
6th May 2016, 08:26 PM
#15
Patrol Guru
That efi hardware place is real near where I collect my parts for work, might stick my head around the door next week.
6th May 2016, 08:31 PM
#16
Rotaredom
Irish
Let us know how you go with them if you do
6th May 2016, 08:43 PM
#17
Patrol Guru
