Results 1 to 9 of 9
Thread: Removing Carbon From Piston, Cylinder Walls, and Block Deck
    Legendary dom14's Avatar
    38 Post(s)
    I found below video is pretty useful as a guide for the above jobs.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (16th July 2017)
    I find it interesting that some "old-school" mechanics would leave the carbon build-up as it improved the compression. Taking into account that I am by no means a learned person, this is the first time I've heard that a hot spot can occur due to the build up. The WD4O does a great job at removing most of the carbon, though.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    subaru upper engine clean.
    38 Post(s)
    Yeah, they do, and that is the case with excessive compression in mine(I bet even though I haven't pulled the head yet to see).
    The problem is that it makes it an absolute PITA with the tuning of the engine, both carby wise & ignition timing wise, 'cos of the hot spots.
    So, I don't think it is beneficial overall to have shyte loads of carbon buildup. A little bit, may be.
    Particularly the thick layer of carbon build up on the piston crown is a real PITA with engine performance, and better have it scraped off.
    Cheetah Outreach
    38 Post(s)
    Bloody expensive though. I used plain water instead.
    I bet there is a backyard chemical alternative that we can add to water. (speculating stuff like detergent, vinegar, etc, )
    Water definitely cleans the spark plug soot buildup & bit of piston crown soot buildup.
    How about Seaform stuff?!!
    https://www.youtube.com/watch?v=agAWXnT4-EQ
    Cheetah Outreach
    38 Post(s)
    Do you guys know a local retailer(either online or shopfront) that sells below bristle discs??!!
    http://www.ebay.com.au/itm/3M-Roloc-...BS-fVh_RyCKLcQ
    https://www.youtube.com/watch?v=zoEh3sq_s1U
    I have the damn air tool, but can't locate the bristle discs.
    Cheetah Outreach
    Jan 2015
    19 Post(s)
    you could spend 3 days cleaning or just spray it with the suby cleaner wait 10 min then wipe it off.
  10. #8
    38 Post(s)
    Ok, cool.
    A cleaning product that costs $75 is something that demands booze before making the decision to get it.
    Cheetah Outreach
  11. #9
    Jan 2015
    19 Post(s)
    Ok, cool.
    it's should be about 20-30 bucks a can..
  12. The Following User Says Thank You to garett For This Useful Post:
    dom14 (17th July 2017)
