Page 875 of 1049 FirstFirst ... 375775825865873874875876877885925975 ... LastLast
Results 8,741 to 8,750 of 10488
  1. #8741
    581 Post(s)
    I saw that vehicle drag a land rover out of the Caledonia River via Dingo Hill, did it like a walk in the park, amazing machines
    He got pulled up Grimme Track, that would be a hard slog pulling someone up that!
    194 Post(s)
    Funny thing was the footage looks pretty tame - not what I remember though going the other . Sure its steep but looked dry and 'grippy'.
    AB (21st November 2018)
  5. #8743
    581 Post(s)
    Yeah it doesn't even remotely look steep in the vid until I saw the sign at the end.
  6. The Following User Says Thank You to AB For This Useful Post:
    PeeBee (21st November 2018)
  7. #8744
    Yep that would be a bastard of a spot to break down!
  8. #8745
    Jul 2016
    4 Post(s)
    Yeah grimme track is where it happened. Litreally turned it off to help someone on the winch then wouldnt start...
    Unfortuantely videos just dont do this track any justice.
    In the section i was about to start to drive it is fairly steep and also rocky.
    Wouldnt wanna come across this track with 40mm of rain
  9. #8746
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Drivers side door wouldn't open from the inside ,found to be a broken plastic guide clip which I've just tek screwed a plastic cable holder in its place .
    New stereo with GPS finally in just have trouble with the Hema card for some reason but will transfer data to USB pen and try it again , slide out touch screen hits the gear stick but will live with it for now .
  10. The Following User Says Thank You to GQtdauto For This Useful Post:
    mudnut (25th November 2018)
  11. #8747
    175 Post(s)
    Hey mate. Keep the Aldi deck receipt very close. That unit failed on me twice, each time after 2 weeks of usage. The screen motor just died.
    I really liked the head unit and simple features but, I got sick of taking it back and getting it replaced. That's if you're lucky for them to have replacement stock.
    I wish there was a way to simply keep the screen deployed and not let it whir in and out all the time.
  12. The Following User Says Thank You to Hodge For This Useful Post:
    Yeti's Beast (24th November 2018)
  13. #8748
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Have read they have problems , this one was put into my daughters car and used for about a year then removed when she changed cars so it might be ok but not expecting much .
  14. The Following User Says Thank You to GQtdauto For This Useful Post:
    Hodge (24th November 2018)
  15. #8749
    175 Post(s)
    Hopefully it works for you.
    I really really like that unit. I like it's single din and screen sits higher as I have where the current Gu unit is , well below eye level. And then I had my UHF unit in the second slot below.
    Shame when my second one broke they had no stock so I had to find an alternative.
  16. The Following User Says Thank You to Hodge For This Useful Post:
    GQtdauto (24th November 2018)
  17. #8750
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Up the shed all morning trying to fix a problem with drivers side mirror , too much angle up and too much angle backwards so while I had the door card off I gave it some angle grinder surgery .
    Happy enough with the up down angle but could have gone a smidgen more forwards .
