14th February 2021, 02:34 AM
Bluetooth problems in pathfinder
Hi
I know this is a Patrol forum, but its hard to find any active forums theese days so this is my last hope so sort this out so i hope its ok.
i just bought an 2011 Pathfinder and found out it has BT, but i cant seem to get my asus rog phone to connect, it just says its unable to communicate with the car, But when i try with an iphnoe its no problem and everything works.
Any sugestions exept changing to an iphone?
14th February 2021 02:34 AM
14th February 2021, 07:53 AM
Very frustrating when Bluetooth doesn't connect, I know.
Have a look at this article which goes through different options to try.
I know you've tested that the cars Bluetooth is working correctly by pairing an iPhone, so you can rule that out.
https://www.technobezz.com/fix-andro...ith-bluetooth/
It might be as simple as something like clearing the cache or maybe needing a software update?
15th February 2021, 06:27 PM
Maybe there's a way to factory reset the Bluetooth in your car.
15th February 2021, 06:34 PM
Moderator
Cremulator
Yeah i was thinking a Software issue too. See if you can connect the iphone and then use it to do a software update to your car. Or take it into a Dealer and ask them to flash the system with the latest updates to your vehicle.
Check out my Toy -->
Rogue Dung Beetle
