Page 801 of 1049 FirstFirst ... 301701751791799800801802803811851901 ... LastLast
Results 8,001 to 8,010 of 10488
  1. #8001
    Aug 2010
    adelaide
    who needs a demister when you have those awsome vents
    OH LEATHER IS NICE
  2. The Following 2 Users Say Thank You to my third 256 For This Useful Post:
    PeeBee (30th September 2017), Yeti's Beast (30th September 2017)
    49 Post(s)
    Brakes while watching bathurst
  5. The Following 5 Users Say Thank You to jay see For This Useful Post:
    Avo (22nd October 2017), GQtdauto (8th October 2017), mudski (8th October 2017), PeeBee (8th October 2017), Softy (8th October 2017)
  6. #8003
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Took the throttle body off the ZD30 today and was surprised that there wasn’t that much gunk in there. I believe it’s the first time it’s been cleaned. Carefully cleaned what I could from the intake and removed the flap off the swirl valve. Egr is already blocked. Don’t know if it’s my imagination but I think it goes better
  7. #8004
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Been chasing a coolant leak for the last couple days, and finally tracked it down to a small section of cracked hose joiner, now just gotta work out which part it is - think it's one of these two:
    http://patrolapart.com.au/product/ge...gr-heater-hose
    http://patrolapart.com.au/product/ge...-to-water-pump
  8. #8005
    Mar 2011
    14 Post(s)
    Also took of my recovery points off that were looking a little bit sad and prepped them up for a quick spray
  9. #8006
    194 Post(s)
    I did a river crossing today, exactly the same way I have crossed this river over 50 times, and had 6 out of 8 blades fracture on the fan hub and have scored the radiator, but its not leaking. Extreme shuddering and vibration at 2000rpm, but being a coolish day, didn't affect the engine temps. Looking for a new tougher fan blade system and will use a radiator shroud next time. the GU patrol , a hiluxDSC01863.JPGDSC01862.JPG and a Terrano that followed and did exactly the same crossing, without shrouds, came thru fine. the fan blades are 3000klm old. Not happy.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Hodge (23rd October 2017), jay see (23rd October 2017)
  11. #8007
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Shitty batch of fan blades maybe ?
  12. #8008
    194 Post(s)
    Reckon the material is too hard/brittle and they are also too close to the core to allow for any deflection. I have not put a ruler in it yet to gauge the differences with the other vehicles. Could have been disastrous based on the tough climb out to the road and a recovery would have been complicated to a point where it could be towed home if it overheated.
  13. #8009
    194 Post(s)
    Rang BD today and they say the blade if off a standard toyota 1HZ, so they are going to replace it with a 3F fan blade - apparently tougher - time will tell.
  14. #8010
    581 Post(s)
    Took it on an epic adventure through the high country for a long weekend with friends.
    Perfect weather, perfect company, really good tracks, climbs, river crossings, etc!
    Loved the new diffs, went up a pretty hard section in particular with full articulation on all sides, short but steep climb and no scrubbing which was a surprise!
    My handbrake cable snapped on a morning start for some reason which was strange but a flawless weekend nonetheless.
    starting to get used to the new diffs, I like a lot!
  15. The Following 6 Users Say Thank You to AB For This Useful Post:
    Bacho86 (26th October 2017), Bush Ranger (26th October 2017), Hodge (23rd October 2017), jay see (23rd October 2017), PeeBee (23rd October 2017), Rossco (23rd October 2017)
