20th October 2017, 01:49 PM
#21
I am he, fear me
mudski
Yeah I think this issue has varied causes from vehicle to vehicle.
Absolutely agree... the Patrol front end is so 'touchy' that over the years I have found that pretty much every single component can be the culprit.
IMHO the slight favourites (but only just) would be the Panhard Bushes and Wheel Bearings as they are the quickest to wear or go out of adjustment.
Yes, Swivel hub preload, tie rod ends etc will all cause the death wobble (my latest episode of death wobble was wheel bearings, prev one was swivel hubs) but those areas usually take a substantially longer time to crap out so the amount of K's on the car can be a hint on where to initially look.
What I do is start with the cheapest/easiest inspections or replacements and work thru the list.
The Following 3 Users Say Thank You to the evil twin For This Useful Post:
bazzaboy (21st October 2017), mudnut (20th October 2017), mudski (20th October 2017)
20th October 2017 01:49 PM
21st October 2017, 10:52 AM
#22
I recommend tyre balancing beads instead of wieghts 1 they dont fall off and 2 they continuously rebalance to give optimum performance. On my BFG km2 285 70 16 s we used a bag and a half per tyre ftom Jac's due to the weight of the tyres and no wobbles .The front end of my 1999 ute is 60-79 k old running the Amarda extreme 2" lift with all new bushes and bearings ,I dont go bush to lay in the dirt working on cars hence the new front end when the E Harrop diff went in.
U have 4 choices in life :U can like it; lump it; love it or shove it, take your pick and stick to it !
