Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Unable to locate TB42 coolant leak - what are some of the less obvious areas?
    Jan 2014
    Adelaide
    Thanks. This was my first thought and I emailed them earlier today as they do not list it on their website.
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Jonesy_sa View Post
    Thanks. I'm currently using the twin-wire screw type that came with the vehicle. I purchased the screw type individually at about $2.80 each from autopro however I may have got a bad one.
    Out of curiosity has anyone ever had to trim a radiator hose? I purchased the Mackay item from Repco which was way to long and required trimming and was stupidly tight. I've never trimmed one before but wasn't sure if this was more common with 4x4's to suite body lifts etc
    Twin wire ones are usually better than the worm type ones, 'cos they usually come with a proper screw to tighten it up properly.
    Trimming may be necessary to customize some of the aftermarket hoses.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. #13
    Jan 2014
    Adelaide
    Quote Originally Posted by Turtle_au View Post
    Water pump internal seal. When cold there is no pressure in the system....when running the impeller creates a low pressure zone behind the seal.....when stopped and hot the pressure gets to the seal and forces the coolant out through the seal and out of the pump body. Had a 750kVA diesel generator do this at work. Had been running for 4 hrs and noticed about a 4 inch round wet patch on the floor under the water pump while it was still running. When we shut it down all hell broke loose and it dumped most of the coolant. It was like someone had turned on a tap.
    On the ball! I was at a loss so pulled the pump to check it. Probably an easy diagnosis if you had one of those extendable mirrors otherwise it was near impossible to see where the leak originated.
  5. #14
    38 Post(s)
    TB42 pump is fairly cheap, so if you suspect it's the pump, just replace it.
    Looks like it took you a while(closer to three months) to pull the pump out.
    So, you've been topping up the coolant all this time?
    Flush the radiator and engine block properly and fill it with distilled water and proper coolant concentrate.
    It's money well spent.
    Cheetah Outreach
  6. #15
    Jan 2014
    Adelaide
    :-) No it was replaced sometime ago. I already had a new one when I pulled the old one off.Just updating the thread for anyone who may come across it.
    With that said, I now have a clutch issue, leaking brake calipers, complacently gone rear axle seal etc etc. So its back off the road!
    Edit - just noticed your username. I think you know my other issues from the threads on patrol4x4
  7. The Following User Says Thank You to Jonesy_sa For This Useful Post:
    Clunk (22nd March 2017)
  8. #16
    38 Post(s)
    What is the clutch issue?
    BTW, extendable viewing mirrors are pretty cheap from spare part shops like Supercheap Auto.
    Cheetah Outreach
  9. #17
    Jul 2017
    bahrain
    hi there i need the engine wiring harness diagram for the 1997 tb42e any one has pic please help.
    thanks
    amq
  10. #18
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by aqahraman View Post
    thanks
    amq
    Mate, just ask the question once, it is pointless to ask the same question multiple times in unrelated threads.
