Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Need to install a secondary cabin heater in my GU (Y61)
  1. #21
    330 Post(s)
    Ideas man Daz. I did see somewhere 12v electric blankets too. Cant remember where though.
    Search Ebay - 12 Electric Blanket and there are lots
    http://www.ebay.com.au/itm/100-Polar-Fleece-Heated-Travel-Blanket-Electric-12-Volt-Truck-Camper-Car-Auto-
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudski (12th August 2015), SiberianPatrol (13th August 2015)
    Aug 2013
    Hello,
    it seems there is an option for a rear heater for GU / Y61 - but only for those manufactured for the colder areas of northern Europe.
    This is what I have found:
    http://nissan.epcdata.ru/safari/wfgy...c/270/27300~A/
    and
    https://partsouq.com/en/catalog/nissan/part/GL/Y61/270
    There are even some part numbers there, so maybe you will be able to source them.
    I will try this modification also, but I have sourced a rear heater unit from a GQ / Y60 and will try to chop the center console and fit this in
  5. The Following User Says Thank You to alexoffroad For This Useful Post:
    SiberianPatrol (22nd October 2015)
  6. #23
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Quote Originally Posted by alexoffroad View Post
    Hello,
    and
    Thanks, Alex. The prices on those rear heaters are astronomical. I doubt I could find one from a wrecker over here. I'll probably wind up going with a 2kBt Webasto air heater installed in the cabin. Very efficient and easy to use.
    http://www.webasto.com/us/markets-pr...r-top-2000-st/
  7. #24
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys , it's shame we can't "Recycle" the rear AC on the Ti models the make heat !!!!! :-) cheers Alex
  8. #25
    I have heated seats in the from,from ebay work very well imo.
    You would need them on a timer or similar as they might flatten your battery if left on
    http://www.ebay.com.au/itm/Car-Heate...QAAOSwu4BVi8tK
    http://www.ebay.com.au/itm/HEATED-CA...d82wF7nCEab5Hg
  9. The Following User Says Thank You to threedogs For This Useful Post:
    SiberianPatrol (24th October 2015)
  10. #26
    Jul 2015
    Siberia
    Thanks, 3D. I have a mob over here who could actually install the heater elements into the seats so that I don't have to worry about the heated covers. I already have heated front seats from the factory. Just trying to figure out options for the rear seats as it a noticeable difference in temperature between the front and back seats.
  11. #27
    As on another thread ,,,run an inverter and use an electric blanket
    not sure on your power source there though.
  12. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    MB (10th June 2017), SiberianPatrol (2nd November 2015)
  13. #28
    472 Post(s)
    @AB mate found an old thread here with diesel heater links and advice above.
    Finally trialled folks a single bed 240v(60w) electric blanket running through my utes 1000w inverter last weekend in around say -2/4 mountain top overnight camping.
    First and second night kept it on 'Low' and after 6 hours snoring chewed through about 0.9/1 volt off the 60amp Optima auxiliary battery. Third night got gready and set it on 'Medium' which sucked the battery down by over twice before to a damaging 10.5 volts. I'd say a minimum 120amp auxiliary system would be needed folks and or diesel air heater I will now investigate further. Portable would be awesome to move between camper, tent, ute pod differing trips etc....
