Page 772 of 1049 FirstFirst ... 272672722762770771772773774782822872 ... LastLast
Results 7,711 to 7,720 of 10488
  1. #7711
    472 Post(s)
    I've plumbed up the air lines, Matfew is kindly helping with all switches and wiring this week mate.
    Winnie (28th May 2017)
    194 Post(s)
    Nearly there......:-)
    Like the idea with the hook Mark, but is the hook big enough????? What a monster.
    MB (28th May 2017)
  6. #7713
    472 Post(s)
    No struggling with double trunk protector ends now mate :-)
  7. The Following 2 Users Say Thank You to MB For This Useful Post:
    PeeBee (28th May 2017), Rossco (29th May 2017)
  8. #7714
    Not a fan of where you have your hook hanging @MB when your winching in the final amount you will put load on that. Chances are that shackle will break and or the chain will stretch. If you end up going 24v then it won't stand a chance.
    The Run On on a Himount is pretty full on mate, nothing like a low mount. In 24v it's full on. You might have seen the comp truck mount a "winch dildo" to their car hi up in PU flex to take up the load.
    I would pull it up around your bar. If your worried about your paint them wrap it in some tape. It will pull hard mate.
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (28th May 2017), PeeBee (28th May 2017)
  10. #7715
    472 Post(s)
    Cheers Daz, appreciated mate. Don't believe it would have been an issue with its old 2.5hp but now the 6hp Iskra/Mahle your advice makes great sense :-)
  11. #7716
    I used to use a 10mm thick rubber O ring out of a 300d storm water pipe which wrapped around the top bar and it worked great for a couple of years.
    I have a winch dildo going on the GQ now
    MB (28th May 2017)
  13. #7717
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Bolted the bonnet back on, due 2 my mechanic's workers not bothering 2 bolt it back on before sending it back 2 me......
    Pretty crappy thing 2 bolt up by yourself!!!
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    MB (29th May 2017)
  15. #7718
    Thanks for the 'jog' TD, as I lave a 4l reservoir and think I will use it to increase the holding capacity of oil in my hydraulic winch, since it's 100mm dia x 500mm long, should be able to squeeze it in somewhere, and it's stainless ax well.
    on the outside of the chassis and body it might squeeeeze in up the front end.
    If its a ute easier eh
  16. #7719
    Did they send it back to you with the spark plug tip removed?
  17. #7720
    TJM sell them they are suppose to be Plasma friendly.
    Much smoother than the yellow latch lock I brought from the sling place
  18. The Following User Says Thank You to threedogs For This Useful Post:
    MB (29th May 2017)
