23rd February 2017, 11:03 AM
Not sure if it's the same for GU's, but I had a weird issue a while back kinda similar to yours. I believe in the GQ, from what I could find/research etc, that there's a common earth that runs into the dash and controls a lot of these.
Mine was frayed in the engine bay and caused me some issues like these, I replaced the bad bit of wire and all good since.
Not sure if it helps, but food for thought.
The Following 2 Users Say Thank You to Throbbinhood For This Useful Post:
dom14 (23rd February 2017), MEGOMONSTER (23rd February 2017)
23rd February 2017 11:03 AM
23rd February 2017, 11:25 AM
I had an occasional fuse "pop" when I had the camper plugged in, seems that at times 10 amp was exceeded (flashers turned on?), auto elec said it was fine to put a 15 amp fuse in (having checked there were no other issues), never had a problem with the trailer attached since.
Note: I would only up the fuse if confident that the load on the circuit was a "legitimate" load and not another "issue". and that he wiring could take it (as advised by a qualified auto elec).
The Following User Says Thank You to TimE For This Useful Post:
23rd February 2017, 11:55 AM
I had a issue with blowing the brake light fuse every so often , after working out what I had added traced it to the barn door table , screw and rubbed on the door brake light wire !
The Following User Says Thank You to gaddy For This Useful Post:
23rd February 2017, 12:10 PM
as suggested check some/all earth straps.
check under right rear thats where most ppl cut into loom for trailer plug
23rd February 2017, 02:16 PM
Dribble Master
threedogs
Yep, pretty much where my issue was a couple of years back, passenger side rear clusters..... wiring was a mess so to it to an auto sparky to sort out
23rd February 2017, 04:43 PM
originally mine was done with scotch loks but after venting
they soldered all connection then shrink sleeved them as you should
Lazy buggers eh
23rd February 2017, 08:50 PM
#17
BIG & BALD
mudnut
Ha ha. Brain fart time. If all else fails, try changing the bayonet style globes. I have come across some that have shorted out in the base.
I had that exact problem and was the first thing I said to him.
23rd February 2017, 08:52 PM
#18
BIG & BALD
Throbbinhood
At this stage everything mentioned is worth pursuing, even if it ends up all good.
The Patrol it self hasn't changed all that much in 20 yrs. lol
23rd February 2017, 08:54 PM
#19
BIG & BALD
TimE
He has put in a 15 amp fuse just to get by but it pop that as well.
So went back to 10amps.
23rd February 2017, 08:55 PM
#20
BIG & BALD
gaddy
I have a feeling it gonna be something like that.
