Page 48 of 52 FirstFirst ... 384647484950 ... LastLast
Results 471 to 480 of 517
Thread: Blocking the EGR Valve
  1. #471
    Feb 2011
    Shed
    45 Post(s)
    I read somewhere only with the addition of a larger exhaust and the blanking plate that the boost can spike to and unacceptable level
    43 Post(s)
    How can I tell what boost I'm getting? I have no additional guages.
    I thought fitting a blanking plate didn't cause any issues except getting error codes on the dash occassionally.
    Do you have an ecu reader. Ie scangauge or similar
    Egr block with stock exhaust is no issue..
    It has enough back pressure.
    But may get the code.
    And it seems it's very exhaust system reliant too.. @TPC doesn't have any boost issues with his holed block plate and 3" yet I did with my full blank and 3" exhaust.
    Boost control has sorted my issues..
    May 2016
    lower west victoria
    30 Post(s)
    I just ordered a poor mans scanguage, so I'll have a look at that, thanks Kallen.
  5. #474
    Jul 2015
    Scarborough, WA
    Hi guys, great thread. I starting researching how to get more towing ability out of my wagon. Read through this and decided I'll blank my egr to start with and see what that does. From what I read I just need the blank plate and something like a scan gauge to clear any errors and compare a few before and after readings. I have a 2012 GU CRD - sounds like it's straightforward. Have no other engine mods... Will see how it goes from this and look at chip and exhaust next.
    Anyone have any towing upgrade suggestions they've used for similar model CRDs? I'm towing a 1.6T camper and it struggles...
  6. #475
    Dec 2016
    Perth
    Hi Guys, great thread. Getting my NADS stuff ready to fit. Has anyone cleaned their intake manifold as part of this ? To me it seems like a good idea to get rid of the accumulated gunk before fitting NADS as otherwise you still have the restricted intake even though it won't get worse.
  7. #476
    460 Post(s)
    Quote Originally Posted by GU09 View Post
    Set aside a day or two when doing the intake manifold removal and cleaning. While its a good idea, its a big job aswell. A lot needs to come off when doing this job.
    GU09 (22nd December 2016)
  9. #477
    May 2016
    lower west victoria
    30 Post(s)
    I started getting the dash warning light after I blocked my EGR and like others I've noticed that is sometimes goes away on it's own. There doesn't seem to be any pattern to when it comes on.
    If you get the app Torque and an OBD bluetooth connector, you can clear the codes that way. I've now got a Kings Scanguagey thing and use that to clear the codes/dash light.
    So if I go with a 3" exhaust and with my EGR blocked how do I make sure my boost doesn't over boost? Do I require yet more stuff to keep that under control? I might just remove all the mufflers etc and stick with the stock size pipe???? What do others think??
  10. #478
    43 Post(s)
    It tends to happen on colder mornings or when air is more dense..
    Yes torque will clear it but why not keep the EDS powered full time as a gauge for multiple things?
    It may over boost it may not..
    Mine did, so fitted tillix and needle valve, so boost is now mechanical..
    May 2016
    lower west victoria
    30 Post(s)
    Do you get enough benefit from fitting a 3" exhaust to warrant the extra work??? Valves, needles, extra gauges & finding somewhere to put them.
    Is it worth the extra work & expense? I only ask because I don't know, if everyone says it makes a huge difference then great, but if everyone says "oh yeah it makes some difference" then .....
  12. #480
    Mar 2017
    Sydney
    Ok so after reading all 48 pages I thought I'd better register. Details of my ride(s) in intro thread but thought I'd provide some info. Had a RedBack 3" exhaust put on the 2011 CRD just after Xmas. Wife and were very pleased with result, general power better across the rev range and turbo seems to spool up a bit quicker. Intend to do the EGR block when I can get access to the vehicle, read intro for more info on that. Just ordered UltraGuage to check boost etc and need to disconnect battery to reset ECU I suspect as wife think fuel usage has possibly gone up a bit since exhaust was fitted...want to do CREB and Telegraph tracks before she comes home in July...So any CRD owner wanting a bit more grunt I do recommend the 3" exhaust it was a very noticeable improvement.
    Graeme
