15th January 2017, 03:20 AM
garett
there are o rings for a/c. they differ in composition to the standard o ring you find.
Yes, they are the green ones. Places like Pirtec sell them pretty cheap.
15th January 2017 03:20 AM
15th January 2017, 03:37 AM
threedogs
mudnut Ive found air con pump to evacuate the system with all hoses are reasonably priced on Ebay.
Im like Dom never been a fan of air-con and delay travelling on days 40 plus, anywhere lol
Yeah, I bought a one from US for around $30. It's not electric. It's powered by compressed air(from a compressor).
Not a bad investment.
http://www.ebay.com.au/itm/BRAND-NEW...QAAOSwm8VUu0mX
Unless mudnut wanna put R134a compatible hydrocarbon refrigerant like mine, it would have to go to an A/C guy to get regassed. R134a is pretty much impossible to buy in Australia without an A/C license.
http://www.ebay.com.au/itm/A-C-Compr...0AAOSwSdZWbzDb
http://www.ebay.com.au/itm/401240248...84.m1436.l2649
15th January 2017, 10:03 AM
Use it or loose it.
That's what the A/C guy said when I took my Navara in to get regassed .
Partners son been driving it ,turned it off cause it uses too much power lol
The Following User Says Thank You to FNqGu04 For This Useful Post:
dom14 (15th January 2017)
15th January 2017, 11:56 AM
The system was supposed to have been serviced not long before I bought the vehicle, according to a sticker on the firewall. I think it will be a case of leave it till some cash is available. That way, the pressure of the gas should stop ingress of moisture.
15th January 2017, 02:21 PM
mudnut
Little bit of gas stays inside, and hopefully that can prevent the moisture from getting into the system.
Once the pressure drops below a certain point, the clutch won't kick in.
It might help NOT using the A/C until you're ready to fix it. That might help preserving what's left of the gas inside the system, I think.
15th January 2017, 02:23 PM
That's what I am hoping. I won't use the bloody thing, though as I don't want oil splashing over everything.
15th January 2017, 05:46 PM
#17
mudnut
Don't forget you need to add a bit of A/C oil as well.
15th January 2017, 06:10 PM
#18
I'll leave it to the mech. Cheers, Dom.
17th January 2017, 02:40 AM
#19
mudnut
Yep, it's probably better that way. Having A/C oil is one thing. Having the right tools to inject A/C oil into the system is another thing.
But, in your case I reckon oil can be added to the compressor on the bench from scratch 'cos it's a new compressor.
