8th October 2018, 07:27 PM
Administrator
TD42T (i maybe) into GQ - Winnie
Gents, just trying to work out what else Winnie would need if he bought a TD42T or Ti block to put into his GQ.
Yes I did it but have a memory like a fish!!!
- Water pump I think is same but the cover for the injector pump gear on timing case is different.
- Block off Vac pump on timing case
- Mount for the power steering pump
- Tacho sensor spacer if TI
- Rear main seal
- Flywheel
- New lines for turbo, oil feed and drain.
- Alternator oil feed and drain (I think I had to replace one of them from the GQ set up)
- Exhaust manifold studs, may as well.
- Engine mounts (just for Winnies situation)
- Gaskets, glue, etc etc
Winnie (8th October 2018)
8th October 2018 07:27 PM
8th October 2018, 08:19 PM
Smart like tractor
You'll need lifters as they're smaller in a silver top.
I have a bare T block, . I have no vac pump though
Just buy a motor that has good compression and send it
96 GQ coil/Cab
08 G6eT
8th October 2018, 08:26 PM
The 747
Ben-e-boy
Sorry just to clarify that the motor we are looking at is a complete long motor.
8th October 2018, 08:32 PM
Smart like tractor
Winnie
Complete as in manifolds pump etc,
96 GQ coil/Cab
08 G6eT
8th October 2018, 08:33 PM
The 747
Ben-e-boy
Need to double check with them but assuming no bolt ons or manifolds.
8th October 2018, 08:54 PM
I put a TI motor in mine,
Removed and blocked the EGR with a kit from performance 4x4 Queensland
Drivers engine mount is different if using the TI pump
Had to use GQ oil pressure switch
I’ve fitted a GQ tacho sensor with a spacer (GQ sensor is longer)
Used GQ loom, had the GU loom to steal plugs if I needed
I’m using the vacuum pump on the timing cover and a GU alternator
My motor came with the turbo flywheel
Everything else was bolt up
Just another Blue over Silver GQ with another TD conversion
The Following 3 Users Say Thank You to Reddave For This Useful Post:
MudRunnerTD (10th October 2018), PeeBee (8th October 2018), Winnie (8th October 2018)
9th October 2018, 06:42 PM
Administrator
Thanks gents, we are just looking for something for Winnie and if it goes ahead want to make sure we have everything sorted for a communal weekend build/install.
The Following 6 Users Say Thank You to AB For This Useful Post:
Hodge (9th October 2018), neet_wagon (11th October 2018), PeeBee (9th October 2018), rusty_nail (9th October 2018), Stropp (18th October 2018), Winnie (9th October 2018)
9th October 2018, 07:23 PM
The 747
Yeah pretty much just wanting to get a grip on what little things will pop up. Would love to be able to install and start up all in a weekend.
The Following 4 Users Say Thank You to Winnie For This Useful Post:
9th October 2018, 11:03 PM
Daily Lurker
The Following User Says Thank You to rusty_nail For This Useful Post:
10th October 2018, 08:04 PM
Moderator
8 have my old water pump your welcome too.
Check out my Toy -->
Rogue Dung Beetle
