Page 788 of 1049 FirstFirst ... 288688738778786787788789790798838888 ... LastLast
Results 7,871 to 7,880 of 10481
  1. #7871
    North brissy
    Near identical size mate, been running perfect until -10C temp trip :-(
    Vacuum is one of the harder things to keep. So it is possible the colder temps has brought out a defect in your system. You will need to check all connections. Even some of the capped ports that exist in the vac systems on these.
    Was it an instant fault or progressive?
    a phone call,booked her in for a airbag refit...i do like her airbags,,,no just to fix that front end wobble...worse on rough roads....
  4. The Following User Says Thank You to Avo For This Useful Post:
    MB (23rd August 2017)
  5. #7873
    472 Post(s)
    Cheers Mat mate, definitely started progressively I felt/think. Morning reversed up to the snow fire area to collect/stockpile wood for camp move next night and had to use handbrake to stop prior to a tree smash @ 1kmph :-( Unsure of the rest of that morning as brakes weren't used until back below 1200m snow level. Was warmer there and all was sweet until the arvo hauling logs back to warm river camp. Drive home was toe tapping Rev's up needed fun Monday :-)
  6. #7874
    North brissy
    Do you know what type of pump the vac pump is? You either have a leak or an issue with the pump. If its a vane pump the vanes might be sticking a little from possible corrosion from condensation/ice and the revs then throws the vanes out as rpm increases. Does the problem also effect the clutch?
  7. #7875
    472 Post(s)
    Clutch is definitely affected too mate, same timeline too I feel :-( The vac pump I'm unsure of its make but is the new GQ4.2 170 amp high vac jobbie Phil kindly found for us on Ebay.
  8. #7876
    that moment when you tell people that your problem,was an EBAY purchase.....MB.....i shake my head
  9. The Following User Says Thank You to Avo For This Useful Post:
  10. #7877
    472 Post(s)
    Certainly cranks out huge power to haul out mates!
    Still going to blow cigar smoke up my own pipes to check for frigid possible system vac splits :-(
  11. The Following 2 Users Say Thank You to MB For This Useful Post:
    Avo (23rd August 2017), MudRunnerTD (23rd August 2017)
  12. #7878
    330 Post(s)
    Quote Originally Posted by stevemc181 View Post
    We'll be heading from Perth across the Anne Beadell, then up to Old Andado and across the Madigan line, ending up at the Gold coast for a wedding. Then up to Fraser Island for 5 nights and back via Alice,West Macs,Uluru, Great Central rd. The route home is not set in stone yet, but we have all the permits required for the route West-East. We are leaving on Sunday or Monday, so counting the sleeps now. The trip is just the missus and myself solo vehicle, and we are both looking forward to a decent break from the routine.
    WOW...... Just WOW!!!!! What an Extraordinary trip that is. Ticking Boxes everywhere you go there sir. Have a great time and travel well.
  13. #7879
    was showing the family them pics today(non white fluffy shit family type)i wouldn't mind camping in a like hut house and taking pics out of the window...dunno about swaggin it n shit..
  14. The Following 2 Users Say Thank You to Avo For This Useful Post:
    MB (24th August 2017), MudRunnerTD (24th September 2017)
  15. #7880
    461 Post(s)
    Fitted a power window relay delay timer. Works well, but it doesn't work on the drivers window. Strange as to why. I pulled the relay out and the drivers window still works, but the other three don't. Hmm. I'm sure I can bypass the drivers window via the switch itself...
  16. The Following User Says Thank You to mudski For This Useful Post:
    MB (25th August 2017)
