7th February 2017, 06:18 PM
Moderator
GQtdauto
Sorry just realised you have a GU , just replaced the GU one as well , auto 8 have Bosch units cheap as chips and still good warranty .
I spent $500+ trying to find out what was making fan belt squeal, in the end it was alternator clutch , should have gone to my regular mechanic but he was flooded in at the time .
From memory alternator was around $265 .
Interesting, so your belt squeal was from the Alternator? did you try Soap or Lubricant on the belt? was it a slip noise or a squealing running noise if that makes sense. @rusty_nail this might be your trouble bud.
Check out my Toy -->
Rogue Dung Beetle
rusty_nail (8th February 2017)
7th February 2017 06:18 PM
7th February 2017, 07:38 PM
MudRunnerTD
I recently replaced my alternator due I belt squealing noise as well - turned out the alternator bearing was stuffed big time... about to fall off. Get into asap Nic if that's what you think it is
The Following User Says Thank You to Bacho86 For This Useful Post:
Hodge (7th February 2017)
7th February 2017, 09:46 PM
threedogs
mudski where can I buy some liquid electrical tape.
Im thinking Jaycar yes???
the back of that plug looks exposed so to seal it would help lots
On a good note at least I didnt have to pull half the engine bay out to
remove it
Yeah Jaycar sell it. I love using it. Works really well. Just buy a small tube of it though. It will last forever. When using it, squeeze a little out and give it a good mix up prior to application. Works better this way if you do. It is messy though as Darren has said.
7th February 2017, 09:51 PM
Gotta be extra careful with the liquid tape as it will go off in the tin or tube. Try sealing it in a bag with the air sucked out.
7th February 2017, 09:54 PM
mudnut
Yeah I had a quite old tube of it and it seemed to have separated in the tube. Id squeeze it out and it would come out clear, then a real thick black substance would come out. A bit of mixing and was all good.
8th February 2017, 08:20 AM
Moderator
mudski
I bought the small can of it and expected the lid to have a brush hanging off it like other adhesives. It was junk. In hindsight I would buy a small disposal brush for the application and throw it away on a job by job basis and I reckon G it would be a great product.
Rogue Dung Beetle
8th February 2017, 08:46 AM
#17
Can anyone spare me 30 mins of their time this morning, seems Ive really hurt myself yesterday.
I'll be unable to put it back together at this stage. I keep falling down ,,,not a good look lol
Oh the reason for all this in the first place was after starting the Patrol my volt meter showed
11.9 volts same at the back of the Alternator, then I noticed the broken wire while I was removjng
the Alt. I might use some 5min araldite on the plug, we'll see.
8th February 2017, 09:56 AM
#18
Years ago we found that 5 minute araldite to be electrically conductive, so make sure you don't have glue connecting the wires together or to earth.
The Following 2 Users Say Thank You to mudnut For This Useful Post:
MudRunnerTD (8th February 2017), threedogs (8th February 2017)
8th February 2017, 10:06 AM
#19
any one know the trick to move the belt tensioner, Ive a 600mm brako bar with a 19mm socket and I cant move it at all
At least the alternator is in, sweating like a pig atm, warming right up now.
8th February 2017, 10:24 AM
#20
nah cant do it on my own Ill need a hand if anyone can help.
Alternators in all I need a hand with is getting the belt on,
after that Im fine with putting the rest togather, too painful
leaning over the guard in into the engine bay.
Any help would be great
