Results 1 to 10 of 13
Thread: Sliders
    Expert daz172's Avatar
    Nov 2013
    Sliders
    Does any1 think that 25kgs each for heavy duty slider/steps is a bit excessive for weight?? They r supposed to go a 97 gq 2.8l turbo diesel
    43 Post(s)
    Quote Originally Posted by daz172 View Post
    Na that's do able..
    Quality tube, thick plate, a bit of sheet..
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MB (19th October 2016)
    Nov 2013
    Had some1 change the Mounts to suit another vehicle and they put these big beefy things on which added a lot of weight, just worried about fuel consumption and if it gonna disadvantage me at all while 4wding
    Definitely won't be a disadvantage while 4WDing. In fact my rock sliders have been one of the biggest advantages offroad! My door sills would be destroyed if I did not have my sliders!
    Naturally it will have a negative effect on fuel consumption but I don't think you'd even be able to notice the difference with 50kgs.
  7. The Following User Says Thank You to Winnie For This Useful Post:
  8. #5
    Nov 2013
    [QUOTE=Winnie;700614]Definitely won't be a disadvantage while 4WDing. In fact my rock sliders have been one of the biggest advantages offroad! My door sills would be destroyed if I did not have my sliders!
    Naturally it will have a negative effect on fuel consumption but I don't think you'd even be able to notice the difference with 50kgs.[/QUOTE
    Ok goodstuff thanx, yeh was just a little worried cuz they were a lot lighter , and now they goin on diff vehicle cuz Wat the mounts were changed for got stolen so I will fitting to car and can change them back to make lighter if I want but it's a lot of work
  9. #6
    43 Post(s)
    50kg won't make much of a dent..
    You don't notice an passenger or 2 in the car.
    Legendary dom14's Avatar
    38 Post(s)
    It will be less weight than carrying a passenger. So the fuel consumption concern is apparently not a valid one.
    But, excess weight should be. Any extra weight you add can be disadvantage or an advantage depending on the terrain. 25kg sounds heavy, but i reckon it would be hard to make strong one with steel bars without reaching that weight.
    Do they make alloy, aluminium rock sliders?!
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  11. #8
    473 Post(s)
    Here's a basic steel chart link guys:
    http://www.hvsteel.com.au/SiteFiles/...comau/pipe.pdf
    Personally wouldn't use any thinner than 3.2mm wall on a 40nb 'Medium' and it weighs 3.57kg/m
    Cheers!
  12. The Following 3 Users Say Thank You to MB For This Useful Post:
    BigRAWesty (21st October 2016), dom14 (19th October 2016), jack (22nd October 2016)
  13. #9
    Nov 2013
    Thanks every1, yeh I decided to go with it and finished them off today , as was said 50kgs would b like carrying a small child in the car so really I don't think it's going to hurt much, here's some pics of Wat I didImageUploadedByMotorculture1476972523.666385.jpgImageUploadedByMotorculture1476972574.671547.jpg
  14. The Following 2 Users Say Thank You to daz172 For This Useful Post:
    growler2058 (22nd October 2016), MB (21st October 2016)
  15. #10
    473 Post(s)
    Looking great Daz :-) That outer bar is huge mate, will look beafy as once fitted up !
    Generally the inner bar closest to the chassis and directly below the sill on most sliders does most of the work and eases catching on the chassis connection stubs. It may pay to throw in another bar mate somewhere roughly pictured below:
  16. The Following User Says Thank You to MB For This Useful Post:
    Winnie (21st October 2016)
