Results 11 to 20 of 25
Thread: Stropp new gu
    Patrol God Stropp's Avatar
    23 Post(s)
    Shhhhh we trying tonpretend he's not here
    I’ll push you over again, this time I will push you into the dam not the bank 😜, btw thanks for the marron
    2003 gu3 td42tdi roaming this great country
  2. The Following User Says Thank You to Stropp For This Useful Post:
    Avo (13th January 2022)
    123 Post(s)
    I’ll push you over again, this time I will push you into the dam not the bank , btw thanks for the marron
    Fuck.....
  5. The Following User Says Thank You to Avo For This Useful Post:
    Stropp (16th January 2022)
  6. #13
    123 Post(s)
    The only time I have ever fallen out if a dam
  7. The Following User Says Thank You to Avo For This Useful Post:
  8. #14
    23 Post(s)
    Took him in and had the tail lights in the rear bar connected with Deutsche plugs for easy removal and replacement if needed and a wire for future use for number plate light, I’ve ordered some motorcycle light bolts same as I had on the other patrol. Also dropped the new second battery in, hopefully late more than one day now 😊
  9. #15
    23 Post(s)
    Today was take the patrol in to adjust the preload on the swivel hub bearings and check the front end for the annoying vibration at 90/95 kph, hopefully it’s been sorted.
  10. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    growler2058 (22nd January 2022), Woof (23rd January 2022)
  11. #16
    Feb 2011
    Shed
    43 Post(s)
    Let us know how you get on. Mine has that annoying wobble at that speed too
  12. The Following User Says Thank You to growler2058 For This Useful Post:
    Stropp (22nd January 2022)
  13. #17
    23 Post(s)
    Ash said can only be preload on bearings or the pan hard bushes or tie road ends, checked everything in the way of bushes so the preload was way off so hopefully that’s sorted it but I’ll let you know
  14. The Following User Says Thank You to Stropp For This Useful Post:
  15. #18
    23 Post(s)
    growler Mate after the preload done it’s taken 98% of the wobble out, just fitted a black widow twin false floor I picked up for $200, fitted a couple of nutserts to bolt the top floor to the drawers so I don’t have to pull the drawers out if I need to remove them
  16. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    growler2058 (30th March 2022), MB (1st April 2022)
  17. #19
    23 Post(s)
    Well I managed to score a brand new darche 270 awning for $800, the guy bought it for a dual cab ute with a rack in the back but when he tried to fit it the passenger doors wouldn’t open because the rack sits level with the cab 😊 stoked
  18. The Following 4 Users Say Thank You to Stropp For This Useful Post:
    jay see (1st April 2022), MB (1st April 2022), mudnut (1st April 2022), mudski (1st April 2022)
  19. #20
    415 Post(s)
    Is it the Kozi or Eclipse you got.
