Page 17 of 19 FirstFirst ... 71516171819 LastLast
Results 161 to 170 of 184
Thread: #The62 MudRunnerTD's New Wheels
  1. #161
    Patrol God Stropp's Avatar
    31 Post(s)
    Oh!! I saw this on Facebook a couple of months ago and had to find it and order one. China china I paid via PayPal just in case it never arrived.
    I arrived before Christmas so I left it packed ans wrapped it ans put it under the tree with a card. "To Dad - From Dad!"
    Happy days!!
    You getting the62 number plate on it 😜
  2. The Following User Says Thank You to Stropp For This Useful Post:
    MudRunnerTD (1st January 2022)
    330 Post(s)
    Brace yourself!!! #The62 is gunna Rock!!! Dripping in Goodness!!
  5. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    growler2058 (4th January 2022)
  6. #163
    461 Post(s)
    Well? We are waiting?
    MudRunnerTD (3rd January 2022)
  8. #164
    330 Post(s)
    I would chew my own arm off before I put a Kings Logo on The62. I would punch myself in the face and then headbutt the ground... lol. Might have grabbed a couple of LED flexible strip lights with dimmers though. No Kings tag for the win.
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (31st January 2024), Stropp (4th January 2022)
  10. #165
    461 Post(s)
    I would chew my own arm off before I put a Kings Logo on The62. I would punch myself in the face and then headbit the ground... lol. Might have grabbed a couple of LED flexible strip lights with dimmers though. No Kings tag for the win.
    To be honest I did think it was a bit strange seeing a pic of you there. Thought you would have bought a Kings Hi lift atleast! Haha!
    MudRunnerTD (4th January 2022)
  12. #166
    330 Post(s)
    OK shit got Real Again!!!! These things! Seriously. Everything is PULL LIKE FARK and pop the clips. Everything is clipped in.
    I have a Factory Nissan trailer plug loom to fit and while I'm there will fit the KO Gear rear locker override switch making the rear factory Locker closer to an E Locker in function.
    I will do a separate thread for the plug and play loom install too.
    In this photo you xan see that factory Sub Woofer. Much smaller than I expected. This is the location that guys are fitting a double ARB compressor in the Ti option.
    The factory loom had a plug waiting for thr loom to plug into which is very bloody handy.
    The Loom though was EXACTLY the right length.... another 150mm would have been nice damn it! It wasn't Free!
    It has a new grommet incorporated so pull and and put through. Winner.
    So here is the internal Trim panel I had to pull out!
    The factory Sound deadening is pretty cool. Like wrapping it in a quilt!
    So while it's off the KO Kit goes in too.
    Selectable switch hidden behind the rear vent. It's a set and forget but if you had to turn it off then a screw driver through the vent to flick it off.
    And this is how I packed up last night..
    Here are a couple of shots of the clips used to hold the panels on. They are identical to the clips holding on the door trims on a GQ...
    Then the instructions again. The pieces MUST be put back together IN ORDER. Take note. I fitted, removed, refitted, removed, item 4 3 times....lol.
    Read the bloody instructions damn it!
  13. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cremulator (5th January 2022), Stropp (5th January 2022)
  14. #167
    Apr 2021
    Brazil
    Interesting! How does each of those selectable options behave?
  15. #168
    80 Post(s)
    And why not have the switch in easy reach of the driver, Darren?
  16. #169
    330 Post(s)
    I haven't really played with the 4wd Selectables yet but from what I understand they change the torque delivery. There is some better info in the manual that I have not really studied yet.
  17. #170
    330 Post(s)
    So this override switch is linked into the factory loom. It changes the function of the switch in the centre console area to select the diff lock. The switch at the rear is purely to switch between the factory Loom and the override loom. For the most part I will never need to turn it off again. If ever I do I can.
    The difflock switch now functions on the same basic principle as an E Locker. On/Off.
  18. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudnut (6th January 2022)
