Page 944 of 1049 FirstFirst ... 4448448949349429439449459469549941044 ... LastLast
Results 9,431 to 9,440 of 10481
  1. #9431
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Washed it, still has red dirt coming out of the door weep holes. Great memories!
    Jack
  2. The Following 2 Users Say Thank You to jack For This Useful Post:
    MB (4th April 2020), mudski (7th April 2020)
    Oct 2019
    installed sound deadener and insulation in doors.
    still got the mass noise liner to go before the vinyl goes in.
  5. #9433
    Advanced gingerboy's Avatar
    Finally got around to reseating flat roof rack a bit further back and replaced all exterior globes with LEDs. Happy as!
  6. The Following User Says Thank You to gingerboy For This Useful Post:
    Yeti's Beast (11th April 2020)
  7. #9434
    461 Post(s)
    Tried to winch a tree today. But nup. The last tree I winched was a big pine tree and that killed it. Nearly finished the high mount.
  9. #9435
    Feb 2020
    shortened transmission input shaft & fitted trans to rear of 6bt to see how far i can move engine/ trans back
  10. The Following User Says Thank You to swamprat For This Useful Post:
    PeeBee (11th April 2020)
  11. #9436
    49 Post(s)
    What else can you do when Melbourne puts on weather like this and you can't go anywhere.
    Wash, wash and wash.
    With alot less drivers (dickheads) on the roads, I'll give the Clubsport a run this week to work.
    Also yesterday put both batteries on a 240v charge.
  12. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Avo (14th April 2020), mudski (13th April 2020)
  13. #9437
    461 Post(s)
    Was there a special on at the local nursery on Yuccas?
  14. #9438
    49 Post(s)
    F@#ken tell me about it. Should see the house nextdoor. It's a pretty long street and just about every house has yuccas or palm trees or both. Front of my house has both and I'm hanging to rip it all up and start again. Doesn't help that the houses are around the 10-15 year range and so are most of the plants.
  15. #9439
    Ballarat Area
    25 Post(s)
    Mine grew six metres in about 12 years, all came as gifts in pots. If you want to remove them I finally found out how to kill them.
    First couple I dug up and pulled out with the winch, bad move. Had literally 100s of suckers come up in the next couple of years.
    The really massive one I cut down to ground level with the chainsaw, it was in three forks at ground level. Painted each stump immediately with straight glyphosate (roundup) and no suckers after 12 months.
    Don’t forget to strip down the chainsaw and clean immediately as they are wet and sticky.
    Jack
  16. The Following 2 Users Say Thank You to jack For This Useful Post:
    jay see (15th April 2020), Winnie (15th April 2020)
  17. #9440
    461 Post(s)
    Yuccas,palms and pines I hate with a passion. I seriously don't see the attraction in any of them. I have no pines left on my block and one yucca left, which will be gone soon.
