Results 1 to 9 of 9
Thread: Let's play spot the problem!!!
    Expert First Pooy's Avatar
    Mar 2018
    Can you spot the problem ? Where's Whally ?
    469 Post(s)
    Bit hard to see off the little phone screen but is that shocker remote hose routing going to get caught by a chunkier big tyre out bush FP mate?
    22 Post(s)
    Too much/heavy spring rate or wrong springs
    96 GQ coil/Cab
    08 G6eT
    Mar 2018
    I have re-routed the hose since the pic but that is'nt the real problem lol
    There are loose fasteners on the floor. Some look to be the shock bush,washer and nut. These need to be installed.....
    Mar 2018
    We have a winner it was supposed to be a 3 inch lift wtf, I checked the code on the box and it said that it was the right spring but obviously it isn't right so I checked the code on the spring and rang superior engineering up and they said not only are they the wrong springs but they are for a Landcruiser wtf the right box wrong springs and not even patrol.springs this is what it was supposed to like like
    Mar 2018
    You are right that is because the springs are so big that I can not even get the rubbers or nuts on
    22 Post(s)
    I'd be moving the rear shock reservoir to inside the chassis rail. The tyre will touch that when it flexes
    Thats problem Number 2.
    96 GQ coil/Cab
    08 G6eT
  10. #9
    Mar 2018
    Yeah that was a temporary mount just to get to home I wasn't really happy with it but I can not mount it where I was supposed to because of the long rang tank and If I go inside the rail I can not get to the reservoir to adjust it but at the moment that is the least of my problems
