Results 1 to 6 of 6
Thread: Cylinder Head Crack Detection Methods - DIY
    Legendary dom14's Avatar
    38 Post(s)
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following User Says Thank You to dom14 For This Useful Post:
    NissanGQ4.2 (18th July 2017)
    We used to check locomotive turbine blades for cracks, using the spray dye and powder method. As for the bubble test, you are gunna need a huge fish tank to to hold a straight six, Dom.
    38 Post(s)
    I picked up a plastic bucket from the side of the road. That should do it.
    Cheetah Outreach
    38 Post(s)
    I've got no idea what you meant above, so I googled.
    https://en.wikipedia.org/wiki/Gas_turbine
    https://en.wikipedia.org/wiki/Gas_turbine_locomotive
    Is that what it is?
    Cheetah Outreach
    Nah. Locomotives here are 2 stroke diesels that use turbos or are roots blown to push air into the cylinders.
    38 Post(s)
    Nah. Locomotives here are 2 stroke diesels that use turbos or are rootes blown to push air into the cylinders.
    Damn! I'm gonna have to pass that. No way I have enough patience to understand what a two stroke diesel is, let alone turbo.
    Cheetah Outreach
