Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Steep downhill control of an RB30 Patrol
  1. #21
    80 Post(s)
    I am not rapt with the lighter gearbox bolted to the RB30. Yes they had a higher first gear, as its guts is designed for skylines. When I was seeking info about rebuilding the first gearbox that let go, a supplier confirmed that it had the same ratios that Commodores ran.
    Legendary dom14's Avatar
    38 Post(s)
    I have read how to descend steep hills in a diesel powered vehicle: 1st low range and do not touch the brakes.
    After only having done a few easy drives on hilly / muddy tracks, I wish to learn how to tackle difficult terrain in an RB30 petrol powered Patrol.
    Compared to the gearing used for a TB42, 1st gear behind the RB30 is very tall and engine braking is minimal, even in low range.
    I have tried to descend some very steep, but short tracks locally, by using different methods.
    Using just the engine, it revs to about 2500-3000 RPM before there is any noticeable braking effect.
    Of course, by that time the speed is suicidal and I have had to apply the brakes so as not to smash into the bottom of the hill or bounce off the track.
    I have also found that applying the hand brake when moving, even very slowly is not an option as it tries to grab and shudder violently.
    I guess there's an issue with the hand brake shoes/drum to give out a shudder like that.
    I've done steep downhill engine braking on first gear, but can't remember I compensated with brake or not.
    I'll have to try again.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
