19th April 2017, 12:45 PM
#671
MB
Can we all be friends now fellas :-) @ Rainsey Graham mate, how's that Manometer going? You are a busy man I know sorry mate, stay the cause though in good time ;-)
Hey sorry for taking so long to get back to you. Ive been madly catching up on my home renovating needs since we have finally ( touch wood) got some clear weather. Got a 4 days away up coming weekend with the missus for our wedding anniversary so definitely won't be using it there...
Weather holding, I'll get back into the pressure measurements week after.
Stay tuned.
Sent from my iPad using Tapatalk HD
The Following 2 Users Say Thank You to rainsey For This Useful Post:
MB (19th April 2017), PeeBee (19th April 2017)
19th April 2017 12:45 PM
19th April 2017, 12:50 PM
#672
No stress mate and congratulations on another good year, Happy Anniversary you two!
rainsey (19th April 2017)
1st May 2017, 05:23 PM
#673
Hi MB,
From our discussions on Hi output alternators.
this is the web site I was referring to.
http://www.nationsautoelectric.com/index.html
cheers
by the way, great donk party
The Following User Says Thank You to poindexter For This Useful Post:
1st May 2017, 05:34 PM
#674
The 747
That reminds me Mark, if you want that TD42 alternator it's all yours. Doing a shed clear out soon so would be good to get rid of it to be honest
1st May 2017, 08:14 PM
#675
poindexter
Thank you very much Ralph mate, appreciated!!
1st May 2017, 08:15 PM
#676
Winnie
That reminds me Mark, if you want that TD42 alternator it's all yours. Doing a shed clear out soon so would be good to get rid of it to be honest Sent from my SM-G935F using Tapatalk
Thank you too Chrisso mate, great folks allofya ;-) !
8th May 2017, 07:06 PM
#677
Navi's video below may help someone out there for 6.5/Trol/Manual-5Stock ratio outa the mountains test, 2,500Rpm/110kmph ;-) https://youtu.be/pdWUAP6vj7M
8th May 2017, 07:27 PM
#678
My BD supplied aftermarket alternator/vacuum pump died on the trip home from the donk party, after a mammoth 2496klm ex new fit net. Looks like the insulation has broken down with a lot of brown/black dust blown out the rear of the casing. BD are sending over a replacement but it's the same make, so might have to look at alternatives, such as stock Nissan in future.
13th May 2017, 09:12 AM
#679
13th May 2017, 09:42 AM
#680
I thought I was the only one setting myself next to impossible tasks! Good luck with this one Mark, the brackets are going to be a head twist, especially mounted off the engine and with the shaft extension. Make sure you use self aligning bearings/pillow blocks i reckon and these need to take the belt tension, so the alternator shaft doesn't see the tension load at all. I look forward to your adventure!!!! I am guessing the config is something like pulley, then a pair of spaced pillow blocks on a plate, shaft coupled to the alternator, would probably go for a coupling that allows for minor misalignment.
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
MB (13th May 2017), Rossco (13th May 2017)
