Page 947 of 1049 FirstFirst ... 4478478979379459469479489499579971047 ... LastLast
Results 9,461 to 9,470 of 10488
  1. #9461
    461 Post(s)
    Yeah I don’t think this is supposed to happen.
  2. The Following 3 Users Say Thank You to mudski For This Useful Post:
    MB (25th April 2020), mudnut (25th April 2020), Yeti's Beast (25th April 2020)
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Time to buy a BT50 Mark
  5. The Following 2 Users Say Thank You to Yeti's Beast For This Useful Post:
    MB (25th April 2020), mudski (25th April 2020)
  6. #9463
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    "Yeah I don’t think this is supposed to happen."
    What made you decide you needed to pull it apart?
    Perhaps you need to read this thread
    http://www.nissanpatrol.com.au/forum...Rebuild-Thread
    Getting the passengers side axle in is really a pain in the A...
    Done it a few times... still get a leak. Last time dropped the level of oil in diff to reduce the "seeping/leaking past the axel seal"
    Going to try the seals that promise to be the bees knees next time
    Trevor
  7. The Following User Says Thank You to tryan277 For This Useful Post:
  8. #9464
    461 Post(s)
    I would rather masturbate with a cheese grater...
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (25th April 2020), Yeti's Beast (25th April 2020)
  10. #9465
    461 Post(s)
    Quote Originally Posted by tryan277 View Post
    Trevor
    It all started with one of the OEM manual hubs had let a little water in and it got a little rusty in there. Stripped it, cleaned it out, then decided to do the other side. Stuff happened in life for a bit, so I put my auto hubs back on but there was no innards to them. I chucked them on just to stop the crap from getting in. Only done maybe 100ks since and now the axle seal is shot. It wasn't real good to start with, this has just accelerated the issue. The end of the axle shaft was just "floating in the hub" with no support at the end of the axle shaft. Because the auto hub I put back on had no guts in it.
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    10G (28th April 2020), Yeti's Beast (26th April 2020)
  12. #9466
    461 Post(s)
    Removed the double din head unit and threw it in the bin. Apparently they don’t like fists. Lol. Piece of cheap Chinese Eonon shite!
    Also found a broken exhaust bracket. Same one has busted twice before.
    So now on the hunt for a new double din head unit.
    It’s good that I work at a place that sells exhaust parts. Found a flange so I’ll cut this and make a decent bracket.
  13. The Following 3 Users Say Thank You to mudski For This Useful Post:
    10G (28th April 2020), Cremulator (27th April 2020), MB (28th April 2020)
  14. #9467
    Pics please, you know the rules
    You know this is going to hurt, idea
    is to keep the blood in ouch
  15. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    10G (29th April 2020), mudski (28th April 2020)
  16. #9468
    461 Post(s)
    Pm sent!
  17. The Following User Says Thank You to mudski For This Useful Post:
    Cremulator (28th April 2020)
  18. #9469
    461 Post(s)
    What did you do to your Patrol today!
    So the upper control arm is fubar. The middle adjuster bit just slides in and out of the end. The thread doesn’t even catch. My choices are. Weld the fecker in and replace the bushes as they are flogged our. Or get a new arm. Which might be exy. As I also need to buy a double din head unit.
  19. The Following User Says Thank You to mudski For This Useful Post:
  20. #9470
    472 Post(s)
    Might still have some OEM arms hiding in the shed somewhere Mark mate if you’d like to hunt for them!
    EDIT: Forgot your beast has a 4”+ lift.
  21. The Following 2 Users Say Thank You to MB For This Useful Post:
    mudski (28th April 2020), PeeBee (28th April 2020)
