Page 1086 of 1450 FirstFirst ... 865869861036107610841085108610871088109611361186 ... LastLast
Results 10,851 to 10,860 of 14491
  1. #10851
    Hey Daz, sorry I just noticed this mate...
    I'll be honest I don't recall having much issue with that.
    I'm very very good at remembering my swear sessions / flying angry spanners and sockets... But not in this case.
    Only minor swearing I recall is needing tiny micro jap fingers and trying to nut 'n bolt everything pretty much blind...
    Yeah that bit!!!!!!!!
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Quote Originally Posted by Softy View Post
    Finding some coolant under my car but i'll be stuffed if i can find where it's coming from (yes i know.. the cooling system) Looks like it's leaking out of the chassis rail.
    I recently had this exact same problem!!! Turned out nine was from a slit in one of heater hoses, wasn’t easy to spot straight away and a PITA to replace lol
  4. #10853
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Mine is coming from the front somewhere..
    This morning it's pretty much all dried up so NFI lol
    Sent from my Pixel
    2003 GU SIII Auto Grenade. All the goodies.
  5. The Following User Says Thank You to Softy For This Useful Post:
    Bacho86 (7th January 2018)
  6. #10854
    194 Post(s)
    Check your overflow bottle assy. I had a small leak and it took me a couple of years to find it - bottle had a tiny split on the back side on a seam.
  7. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    growler2058 (6th January 2018), Softy (6th January 2018)
  8. #10855
    May 2016
    lower west victoria
    30 Post(s)
    i was surprised to see the actual spring seat was split too! Damn it.
    Yeah, I was surprised to see that as well, odd I reckon.
    I've just replaced my rear coils with lighter ones as I don't carry much stuff in the rear 90% of the time and was concerned that stiff coils wouldn't compress enough and put too much stress on those mounts.
    Hope it all goes back together easily for you mate.
  9. The Following User Says Thank You to 10G For This Useful Post:
    MudRunnerTD (6th January 2018)
  10. #10856
    May 2016
    lower west victoria
    30 Post(s)
    When did you last replace your chassis coolant? May be overdue?
  11. The Following User Says Thank You to 10G For This Useful Post:
  12. #10857
    .......... TPC's Avatar
    63 Post(s)
    That is the reason I made sure my model Patrol was the air-cooled chassis variant, hate getting a coolant leak in the chassis.
  13. The Following 3 Users Say Thank You to TPC For This Useful Post:
    GQtdauto (6th January 2018), MudRunnerTD (6th January 2018), rusty_nail (10th January 2018)
  14. #10858
    175 Post(s)
    Hey mate is yours a 3L CRD? They have a common front timing cover coolant leak. Mine had it. And it was a bitch to diagnose !
    I don't think this is your issue.... BUT ....
    When you said, that today it all dried up, I brought back memories for me. lol
    Basically, when motor is running / hot, no leak.... If i sat the car untouched for a day or so, leak appeared. Basic theory, when motor heats up, metal expands, sandwiching the timing cover. Motor cools down for a lengthy period, metal shrinks, small leak occurs.
    Mine mostly accumulated at the bottom near the A/C. But sometimes I found it sitting under the passenger front chassis. Later on I realized it was making its way along one of the hoses and down onto the chassis.
    Here is more threads on it...
    http://www.nissanpatrol.com.au/forum...e-timing-cover
    http://www.nissanpatrol.com.au/forum...-leak-CRD-3-0L
  15. The Following User Says Thank You to Hodge For This Useful Post:
  16. #10859
    May 2016
    lower west victoria
    30 Post(s)
    Bugger me, I didn't know they brought out an air cooled chassis version. And here's me thinking I knew it all
  17. The Following User Says Thank You to 10G For This Useful Post:
  18. #10860
    May 2011
    Radelaide
    5 Post(s)
    Mines a DI and 99% it's not coming from the motor. Just went and out to visit my mate Dan... Dan Murphy and I was greeted by it leaking again ffs.. header tank seems to have lost a little bit of fluid... So going with that. Will look into it more tomorrow once it cools down, and I have Turkey's to drink now 👌
    Sent from my Pixel
