Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Temp gauge reading cold
    Aug 2015
    Yea that sounds about right usually only does it on first start up of the day or if it's been left awhile
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by garett View Post
    is like choke kicking in? the efi should have a choke like running condition if the temp drops it could be bringing the revs up to warm the engine.
    Yeah, but it ECU shouldn't do that randomly, should it? May be it's not that random as OP says, but only when the engine's cold started.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. #13
    Aug 2015
    Hmmmmmm is there like a stepper motor or something like that on rb30 motors?
  5. #14
    38 Post(s)
    Quote Originally Posted by lars04 View Post
    Stepper motor in where?!!
    I reckon you experience high idling revs for too long when engine's cold started. Ideally it should settle once the engines warmed up, but that can be some time in cold weathers. Replace the cold running thermostat asap though. No good can come out of it, as I've experienced with mine.
    Choking method in EFI ones afaik is the ECU causing the injectors to spray extra fuel.
    Cheetah Outreach
  6. #15
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    i think he's referring to the idle bypass motor.
  7. The Following User Says Thank You to garett For This Useful Post:
    dom14 (4th March 2017)
  8. #16
    Aug 2015
    All good, found out I've got a sticky cable or something if I push up with my foot on the accelerator and it idles nice.
