2nd December 2016, 12:21 PM
#41
dom14
According to fleabay, stainless steel ain't any dearer than mild steel.
It's that ones that're purposely made for Patrol arent' available cheaper.
I wonder whether I can modify a standard stainless steel muffler of the same size to suit mine.
Of course you can. A muffler is just made at a generic size, and in and out orientation. Its the pipes on either side that matters.
dom14 (2nd December 2016)
2nd December 2016 12:21 PM
2nd December 2016, 12:29 PM
#42
mudski
Thanx Mudski mate.
That's what I've been waiting to hear. I like my hobby.
Dom
2nd December 2016, 04:54 PM
#43
I'm thinking about getting a reasonably close stainless steel muffler from a wrecker and modify it to suit mine.
Getting a mild steel used muffler is a waste of money I reckon, 'cos it may end up the same way in no time?
2nd December 2016, 06:59 PM
#44
mufflers are over rated just put in a bit of pipe ... :P
The Following User Says Thank You to garett For This Useful Post:
dom14 (3rd December 2016)
2nd December 2016, 07:15 PM
#45
You've gone around this all wrong, Dom.
It goes like this: "Honey, the muffler has got some loose baffles (truth), and I have been informed that they could block the muffler and stuff the engine (truth).
After all the trouble I've had with the whole system it would be easier to get a whole new system than mucking around with individual components (some what true). So the engine pipe flange doesn't stuff up, we should get headers (totally true). They should also give us better economy (truth).
Do not however mention the extra ten percent (achievable, so truth anyway) increase in horsepower.
2nd December 2016, 10:55 PM
#46
On the subject of stainless vs aluminiumised steel, the stainless is more brittle & prone to cracking. Unless it is a show car, go with the aluminiumised steel.
The Following 2 Users Say Thank You to GeeYou8 For This Useful Post:
dom14 (3rd December 2016), mudnut (3rd December 2016)
3rd December 2016, 12:10 AM
#47
mudnut
Yeah, I know you have evidence to prove the extractors improve the horsepower without upgrading the pipes or the muffler, but I reckon you got lucky with a good set of extractors and a good carby tune up.
Extractors are cheap enough to buy secondhand, but way too much PITA for me right now.
Muffler's gota be replaced. No doubt about that.
Here's the vacuum gauge test on exhaust back pressure.
As you can see the the vacuum isn't dropping as I increase and hold the rpm.
https://www.youtube.com/watch?v=UTK1...ature=youtu.be
So, it appears there isn't much back pressure at the moment, according the vacuum gauge test, but I'm
sure the muffler is gone anyway. Next time the baffles start rattling inside it might block the whole thing.
BTW, it appears it's holding at a higher level(23 InHg) at steady high revving than at idling vacuum(20), then goes even higher(30) when I let go the high rpm.
Does that look all good?!
3rd December 2016, 12:11 AM
#48
GeeYou8
Ok, cool thanx. I didn't know that.
3rd December 2016, 12:17 AM
#49
garett
I would, when I get to turbo arena.
3rd December 2016, 12:25 AM
#50
dom14
Dunno. Maybe @nissannewby can tell you what is happening.
