1st September 2016, 02:13 AM
Moderator
oncedisturbed
@Cuppa here is everything you need to know mate.
Check out my Toy -->
Rogue Dung Beetle
1st September 2016 02:13 AM
1st September 2016, 09:19 AM
Travelling Podologist
Thanks Darren. That's helpful. Have had a brief read through. I'll check out access with the bullbar when my back allows.
It does appear that it would just need the gears cleaning & re-greasing, as I imagine it has done very little work during it's life & the grease has probably gone hard. The brake mechanism & motor shouldn't need touching. The main issue for me (if there is one) will, I think, be getting the winch off & back on to the vehicle.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3 Genie exhaust + dynotune, 2 lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare)
1st September 2016, 09:31 AM
Moderator
Cuppa
You could throw a rope around each end and tie it up with the rope out the top. Unbolt it and the ripe will take the weight. Unbolt it and lower it down.
Even if you get it off and serviced, lining someone up to give you a lift back in will be simple enough. Does it have wire rope or synthetic rope? Un spool the wire rope and remove before you take the winch off will strip half its weight.
Rogue Dung Beetle
1st September 2016, 09:49 AM
MudRunnerTD
Synthetic. I replaced the wire rope to save weight ages ago. From memory taking it off & replacing the rollers with an alloy hause was worth over 13 Kg.
1st September 2016, 10:17 AM
MudRunnerTD
Yeah I used a motor bike tie down and loop it around the top of the bar and then around the drum of the winch through the top of the bar, and then lower it down on a crate by lightly pressing on the cam lock on the tie down.
1st September 2016, 12:56 PM
optic
Thanks for the above info.
Looks like im i strife as the head size is 16 or 17mm square, bolt dia 10mm.
I do recall that they were square headed bolts in this winch which i have had for a long time.
Near enough to 20 years i would think.
Ill get some 10mm bolts and rebuild the head to suit the T slot.
The other concern i have is, i had this winch mounted to the inside of an 8 inch channel bull bar home made and never bent, trees and all.
It was that heavy i had to up grade the springs in the gutlux.
The winch was mounted against the inside of the channel and a direct pull against the T bolts.
So the forces were in a straight line against the mounting housing.
It is now going to be mounted 90 deg to the mounting points in the cradle.
My concern is will it break under strain as the mounting brackets are only ally?
I would hate to find out the hard way in the middle of no where.
In any case thanks for the above info.
Cheers.
Are these the bolts you're after???
http://www.ebay.com.au/itm/Warn-8274...8AAOSwbYZXa9JP
1st September 2016, 01:00 PM
#17
Cuppa
If you kept your old SWR take it to a place like Nobles,,,all lifting and safety
and get them to swage eyelets on each end, makes a very good rated,,long
extension cable.
1st September 2016, 01:35 PM
#18
@oncedisturbed Hi Jase whats the difference between the XD and the XP is it just motor size ??
1st September 2016, 01:38 PM
#19
threedogs
extension cable.
SWR - Wire rope?
I think I offered it to others here but no-one took me up on it. It was in perfect nick. After sitting coiled neatly inside a bucket for a couple of years I finally chucked it in the skip I hired to clear up all the metal stuff laying around our property before we moved.
BigRAWesty (1st September 2016)
1st September 2016, 01:41 PM
#20
The 747
threedogs
extension cable.
Better off buying a synthetic rope to use as an extension. The cable weighs a ton and is bulky to store.
The Following 2 Users Say Thank You to Winnie For This Useful Post:
BigRAWesty (1st September 2016), MudRunnerTD (1st September 2016)
