Results 11 to 20 of 24
Thread: Cracked Fuel Tank
    43 Post(s)
    How do you "purge" with exhaust gas? Where do you get nitrogen gas to purge the tank?
    Plump your exhaust to the fill hose and undo every hose to let the exhaust gas out..
    Nitrogen from a gas supplier.
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    dom14 (12th May 2016)
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Use a longish hose or run the hose through a bucket of water as they can get Dam hot.
    Any BOC, Supagas or air liquide outlet can hire you a cylinder, but exhaust gas is the cheapest option.
    As you won't have fuel in your tank to run the car use a motorbike or mower.
    It's all the same.
    2012 GU8
  5. The Following User Says Thank You to rusty00 For This Useful Post:
  6. #13
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by rusty00 View Post
    It's all the same.
    Purging of the petrol tank is done to get rid of any left over petrol in the tank, right?
    So, it won't "explode" while trying to weld the crack.
    What if, after draining all the petrol, I leave the tank out in the sun for few hours for any left over intank petrol fume to get out??!!
    I understand that means pulling the tank out. But, I always thought, in order to do a proper welding job of satisfaction,
    having the tank on a bench is the ideal thing. Welding stuff under a vehicle(with no access to a hoist) is easily said than done.
    While doing welding work on the van chassis(no hoist). I had to use quite a few of tree trunk cut outs to raise the van high enough to be able to do all the welding work. Even with that, it was a bitch of a job. I use the same thing to raise the rear of the vehicle high enough when I was doing the rear diff center.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  7. #14
    Jun 2015
    South Eastern VIC
    It won't rid the tank of fuel, but it will creat an environment where an explosion can't happen by removing the oxygen.
    If you have no oxygen then no fire can start.
    It is best to remove all fuel any way you can to be sure and to make sure you are happy with the process.
    If you have a mig welder and can access the tank crack you will be okay as long as you can squeeze yourself or the welder in place.
    We use to use this method to cut tanks in half and weld when fitting gas tanks and also for repairs.
    Never ever had a problem.
    2012 GU8
  8. #15
    Since the crack was due to a stone, would you drill a small hole at each end before welding it anyway?
  9. #16
    38 Post(s)
    That means the tank has to be air tight while welding, otherwise oxygen would squeeze in, regardless of the purge.
    Why wouldn't oxygen get into the tank from the very crack you're trying to weld??!!
    Cheetah Outreach
  10. #17
    38 Post(s)
    I'm bit lost!!! Drilling into the tank?
    Cheetah Outreach
  11. #18
    When we had cracked components on locos or whatever, we would drill a hole at each end if possible so that the crack would not continue after the weld was done.
  12. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (13th May 2016)
  13. #19
    Jun 2015
    South Eastern VIC
    No, just purge it or wash out all the fuel or take it to a professional.
    The crack has nothing to do with the oxygen, you are removing the inner space oxygen with the purge.
    2012 GU8
  14. #20
    38 Post(s)
    I'm sure you are right, as you have experience of doing it. I'm only trying to understand as I haven't welded a petrol tank before. I' guessing you use exhaust gas to purge any left over fuel(from hot exhaust gas)?
    Or do you need to keep the engine running, while the exhaust is attached to the petrol tank & while you're welding?
    Cheetah Outreach
