Results 1 to 10 of 13
Thread: GQ Patrol Brake line part - WTB
    194 Post(s)
    I am looking for the brake line distribution block that sits on the chassis on drivers side chassis rail, next to the spring tower, it has 5 lines going into it. Does anyone have one lying around they want to sell? I have contacted PAP and Hall4x4 and they dont have any in stock. , and a couple of Facebook contacts with GQ wrecking etc have failed to respond. Needs to be from a LWB, and preferably a late model just in case there is any quirty BS with the threads - which there shouldn't be.
    465 Post(s)
    Is this the part Phil?
    194 Post(s)
    That is the baby, where did you find that? Is it for sale and how much do you want for it?
    194 Post(s)
    Sorry its from Patrol UQ, bit visually overloaded right at this moment - I can order from them direct I guess.
    thanks Mark, big big help.
    465 Post(s)
    You can order direct from Partsouq but I do believe this part is no longer available. Maybe contact a Nissan dealer and get them to check. They should be able to check within all dealers in AU.
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    If all else fails it looks as though it could be knocked together pretty quick by any engineering shop.
    1989 LWB 5-Seat, TD42
  8. The Following 2 Users Say Thank You to mihit For This Useful Post:
    mudski (1st May 2023), PeeBee (2nd May 2023)
    194 Post(s)
    Thanks I have contacted PAP and they are waiting for a GQ LWB to come in this week, plus there is a nissan Wrecker in Bayswater who may be able to help, not Hall4x4 this time, and there is a guy in Pakenham who may have one, but wont post it.
  10. #8
    194 Post(s)
    Patrol A Part have one on a vehicle now, coming off this arvo for tomorrow pickup. No stock anywhere apart from the other guy in Pakenham. Low profile double flare tool arrived yesterday, so with luck will get onto this tomorrow or thursday.
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (4th May 2023), mudski (3rd May 2023)
  12. #9
    Apr 2021
    Brazil
    PeeBee, when you go to PAP to pick your part, do you mind checking if they have a full set of USED GU4 fender flares / over-fenders and how much is it worth? It can be any color, even made of different color parts to make it a full set...
  13. #10
    194 Post(s)
    Sure, will do. They are very responsive to emails also as I have found out, sending photos of what they have as well, however I will be there this morning and will ask.
