23rd November 2017, 06:27 PM
#51
bigguwesty
And while were on bottles (which look fine), you only need to crack the bottle open, not 100% like you did in your video.
When on opening a bottle it's only ever 1/4 turn, 1/2 max if I'm feeling generous or bottle is getting empty..
The pressure these bottles are under you don't need much..
Ok, cool. I'll try with slightly open bottle, but from memory, the regulator pressure meter jumped all the way to 25Mpa from memory, even when I opened a little bit.
The Following User Says Thank You to dom14 For This Useful Post:
BigRAWesty (23rd November 2017)
23rd November 2017 06:27 PM
23rd November 2017, 06:33 PM
#52
Ok, guys. This is the video I would really appreciate if you watch it & give me a verdict.
The first part is when the welder is turned off and the second part with the welder turned on, and with the same result.
Basically what I did is to open the bottle valve and then shut it allowing some gas to be trapped between the bottle valve & MIG nozzle.
The flow meter is fully opened. Now, instead of the dancing of the ball as in the previous video, the flow meter ball goes up to around 10L/m(the maximum flow rate that I've been able to get out of the flow meter so far, assuming it's accurate), and gradually drops without any dancing as the gas runs out.
https://youtu.be/CFr-xfYATOg
So, my question is,
Why the flow meter behaves normally(if you can call it normal) above but totally different when a constant pressure is applied by opening the bottle valve?
Bad regulator? and perhaps bad flow meter as well?
To make sense of what I'm talking about, here is the previous video with bottle valve fully opened.
https://www.youtube.com/watch?v=F1ur...ature=youtu.be
23rd November 2017, 06:46 PM
#53
dom14
So, my question is,
Saying video is not found sorry mate.
So I do agree that the reg isn't brillant.
However the pulse of gas would be nil by the time it gets to the nozel.
Mine bounces a little but settles after a bit of consistent flow.
However.
If you can hear the flow and feel it on your cheek you have enough flow..
What size wire are you running??
dom14 (23rd November 2017)
23rd November 2017, 06:49 PM
#54
Westy might be onto it , only open the gas bottle max half a turn not full , the first video is how it should behave second is abnormal mate and explains the crap weld but I'm still worried about the rapid torch movement .
Try it again only opening as Westy says quarter to half a turn .
Have you checked your email mate I sent you this info yesterday .
The Following User Says Thank You to GQtdauto For This Useful Post:
23rd November 2017, 06:50 PM
#55
bigguwesty
However.
If you meant the bottle, it's size D.
The tip and the wire is 0.8mm.
What did you mean the video is not found? Not working on your end?
It seems ok from my end.
Thanx
23rd November 2017, 06:52 PM
#56
GQtdauto
Ok, cool. I'll give it another go now and see how it goes.
23rd November 2017, 06:55 PM
#57
I'm wondering.
How is it possible for the gas to flow from the trigger at the nozzle when the welder is turned off, as in the first part of this video?
Is it normal?
I was thinking the gas valve in the MIG welder is activated electrically, when the trigger is pressed on the MIG gun.
https://www.youtube.com/watch?v=CFr-...ature=youtu.be
23rd November 2017, 07:08 PM
#58
dom14
Thanx
Yea video is not working.
So .8 is the max that machine can handle.
For comparison my 180A mig is recommended to run .8
23rd November 2017, 07:37 PM
#59
bigguwesty
Thanx mate. I'll try a thinner wire(0.6mm?) then, and see how it goes.
BTW, opening the regulator slightly or running the bead slowly and steady won't make any difference, neither would doing it on a super clean
piece of steel.
Videos are working fine. Something's not right with your end, perhaps the youtube app in your phone may be playing up.
23rd November 2017, 07:38 PM
#60
GQtdauto
Thanx for the email mate, but I didn't check it. I'll check it shortly.
