Results 1 to 5 of 5
Thread: Dash High Beam Indicator Always on
    Aug 2014
    Perth
    10 Post(s)
    Hi All,
    Just noticed this today when I was driving and put the headlights on, no matter what position the stalk is in the high beam indicator is on. First thoughts are a blown fuse but haven't checked them yet. Had a look the left hand headlight in low beam doesn't light up, high beam the spotties come on.
    Anyone seen this before?
    Fish
    have you tried turning it off and on again?
  4. The Following User Says Thank You to Avo For This Useful Post:
    gubigfish (17th September 2017)
    Aug 2014
    Perth
    10 Post(s)
    Funnily enough I have
  6. The Following User Says Thank You to gubigfish For This Useful Post:
    Avo (17th September 2017)
  7. #4
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Faulty earth on the LH headlight and its getting an earth feed through the dash light?? Also try disconnecting the spotlights and see if the car lights perform properly then.
    Tony
  8. The Following User Says Thank You to 4bye4 For This Useful Post:
  9. #5
    Wot he said ^^^ and...
    Yes seen it a fair few times and every time it has been either a high resistance earth on the Headlight plug earths themselves or the loom if aftermarket... so def the first place to check.
    I have also heard of it being said it was a faulty stalk switch but not seen it personally
  10. The Following User Says Thank You to the evil twin For This Useful Post:
