5th August 2017, 06:16 PM
#7821
Fabricated the new 4" SS snorkle, ready for welding out next week, might get it powder coated as well, black. Changed out the rear sway bar rubbers, stuffed around with flowmeter setup - looks like the flowmeters are the wrong range, so back they go.
The Following 4 Users Say Thank You to PeeBee For This Useful Post:
Clunk (5th August 2017), MB (5th August 2017), Rossco (5th August 2017), VK2FMIA (5th August 2017)
5th August 2017 06:16 PM
5th August 2017, 07:45 PM
#7822
PeeBee
Ooh nice, pictures? Keen to see it when it's done, looking forward to my millie job should be nice i hope . . .
5th August 2017, 07:51 PM
#7823
Rossco
I will stick up some photos when I have it installed. Currently tacked up and waiting for the welders touch to finish. MB posted up some shots of how Millweld rework the safari hole in the guard. I am undecided yet how this coverplate will look, so need to think a bit more. The millweld setup is very neat for sure. When is your getting fitted Rossco?
5th August 2017, 09:07 PM
#7824
PeeBee
October 2nd i think. Can't wait, although it's gonna be a nervous drive up to Mansfield . Might have to leave at sparrows . . .
Sent from my SM-T800 using Tapatalk
5th August 2017, 10:05 PM
#7825
Adventurist
Gave it the first oil change of it's young life Made a mess of the concrete though!
The Following User Says Thank You to stevemc181 For This Useful Post:
5th August 2017, 10:40 PM
#7826
Prepped and painted the rear bumper where I had scraped the paint before installing the rear view camera. Then touched the wet paint, tried to fix it, made it worse. So what did I do to my Patrol today? Nothing really. Ill sand it back and start again tomorrow.
The Following User Says Thank You to 4bye4 For This Useful Post:
5th August 2017, 11:11 PM
#7827
Found the cause of my front hub noise @MudRunnerTD. The outer locking gear was jumping on the inner gear thats on the axle shaft. I remove it to find the outer gear not engaging far enough out when locked. only by maybe 2mm. So I pull the hub right apart to adjust it and the thread section in the middle where you adjust the hub is actually cracked.
Warranty claim coming....
MB (12th August 2017), MudRunnerTD (6th August 2017)
5th August 2017, 11:28 PM
#7828
VK2FMIA
Installed new LED H4 globes yesterday & took it for a run last night. Low beam are excellent, high beam not so good, not much brighter than low but all good when the LED driving lights kick in. Will be interesting to see if the H4`s hold up.
Slowly upgrading all lights to led, T10`s on the way for parkers, side indicators & number plate light. Looking at replacing front & rear brake, turn & tail lights down the track.
I might just hold off on swapping out my hid globes to these based on what you found. I reckon my hid' are great, just as illegal in vic as LEDs, - what did you change from , halogens? I have the globes sitting there to swap, but still not convinced. I run led light bars for high beam and they are great, running them at 28v, so just about nameplate output.
6th August 2017, 12:13 AM
#7829
mudski
What brand hubs?
6th August 2017, 12:29 AM
#7830
sooty_10
What brand hubs?
Cheap OEM copies. eBay specials. I'll see if I can get the busted hub swapped under warranty. But my auto hubs are a bit worse for wear, hence me buying these, so I might have to fork out the coin for genuine hubs.
Maxhead (6th August 2017), Rossco (6th August 2017)
