5th August 2017, 07:16 PM
#3971
Patrol Guru
MB
This looks damn interesting. If only it would work with 12v input does it have 2 preset pressures? An offroad and onroad pressure setting without having to manually go up and down every time?
Pull up plug it on and it airs down then when your done plug it back on and it auto airs up.
Can you add a hose line to the deflation vent? I have a wagon would be good if you could externally vent it, more for the noise etc.
Something like this would be mint with an endless air system.
The Following User Says Thank You to sooty_10 For This Useful Post:
5th August 2017 07:16 PM
5th August 2017, 07:30 PM
#3972
sooty_10
Ok if you have the inverter on board but a lot of us do nowadays, wonder if it's 240 in but reduced to 12 volt like a lot of electronics.
The Following User Says Thank You to GQtdauto For This Useful Post:
5th August 2017, 07:47 PM
#3973
I'll have to take another look at it tomorrow for ya gents, snuck out of a birthday dinner restaurant here :-)
The Following User Says Thank You to MB For This Useful Post:
GQtdauto (5th August 2017)
6th August 2017, 08:20 AM
#3974
UncleFrosty
Use female Nitto fittings on the manifold to hold pressure whilst connecting. Also means you won't need plugs for outlets not being used.
Top idea UncleFrosty mate. I do now remember reading on here somewhere of blokes using those fittings, specifically 4 of them one nearest each tyre for only short hookup hoses needed.
I also just realised that it is the old screw on 'open' type inflators that was my concern.
The push/click on ones wouldn't let air out of the others awaiting connection I believe.
MudRunnerTD (7th August 2017)
6th August 2017, 08:24 AM
#3975
sooty_10
G'day Sooty mate, yes it does apparently have 2 x preset pressure buttons.
The exhaust vent may be a little tricky to connect a hose to external though but I'm sure someone can help us figure it out mate.
6th August 2017, 08:29 AM
#3976
GQtdauto
Can't seem to find anywhere what internal power it uses Rob. Seems to only need 10watts though. I'm thinking if I pull it apart for a picture might void my warranty and calibration certificate :-(
GQtdauto (6th August 2017)
6th August 2017, 08:34 AM
#3977
Yeah probably best not to pull the cover off MB but thanks , I do have an inverter set up so will wait and see how you hook yours up .
6th August 2017, 08:36 AM
#3978
For my current needs gents think I'll just stick with the single hose reel for now. I generally run an extra 2psi in my utes rears so a cool level all function would hinder that for me. Time wise I'm thinking my compressor will only do what it can do too. Connecting up four small hoses for us I imagine would take as much time I think as shifting the one main hose four times. Would be pretty cool though being able to say pack up camp away from the truck whilst all four inflate simultaneously:-)
6th August 2017, 08:38 AM
#3979
The 747
MB
You'd certainly get some jealous campers eyeing you off!
The Following User Says Thank You to Winnie For This Useful Post:
6th August 2017, 08:48 AM
#3980
Patrol Guru
Cheers @MB. I need to get off my arse and install an air tank and endless compressor. Then I can worry about these sort of luxuries. looks good though.
The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
GQtdauto (6th August 2017), MB (6th August 2017)
