Page 841 of 1049 FirstFirst ... 341741791831839840841842843851891941 ... LastLast
Results 8,401 to 8,410 of 10488
  1. #8401
    49 Post(s)
    As there's a topic going one here. I'll ask the question.
    I get what MB is saying about the charger putting charge into both batteries. My problem is that currently I have 2 different chemistry batteries aux is agm and starter is calcium. I know that I need to have different settings for each when charging, but when the charger is connected it's charging both as one system. Will putting an isolater in like the one pictured work. If I have it off/closed and the charger is connected to the aux it will only charge that one and when connected to the starter will only charge the starter?
    Is that right..
    When the starter needs to be replaced what is recommended so it will match the aux.
    Guys
    581 Post(s)
    Packing the GQ to take the solo daddy kids trip Thursday to Sunday up the Murray.
    If anyone here miraculously is heading around Strathmerton / Tocumwal area then PM me.
  4. The Following 4 Users Say Thank You to AB For This Useful Post:
    mudski (3rd July 2018), PeeBee (3rd July 2018), Plasnart (3rd July 2018), Rossco (3rd July 2018)
  5. #8403
    49 Post(s)
    Is that right..
    Am I over thinking this.
    Surely there are people with 2 different batteries that plug a charger in and just charge.
  6. #8404
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    No , I charge them independently because a Calcium needs up to 16 v to charge properly and remove stratification where as the Agm shouldn’t go above 14.8 or you risk damage to it.
    If the batteries are already charged and you want to just maintain them while not in use then being connected will be fine ,but charge on the AGM setting
  7. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    jay see (3rd July 2018)
  8. #8405
    49 Post(s)
    Quote Originally Posted by Yeti's Beast View Post
    Thanks mate.
    Batteries are charged, cars driven everyday. I was told to throw a charger on them every 3-6 months to keep them healthy extend their lives.
    Think I'll still go with the isolater.
  9. #8406
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Thanks mate.
    Agree with Yeti's Best for independent charging. IMO, Good idea to occasionally charge your Calcium battery up to its 100% SOC voltage (eg: 16volts) if you are not already doing it as the alternator in the vehicle would be designed for FLA charge regime and would not reach the Calcium max charge voltage.
    Also, have read that AGM have a lower float voltage than FLA. I guess AGM batteries would be adversely effected on long trip sitting at higher float voltage especially in prolonged hotter operating conditions (somthing to consider).
    The isolator you illustrated would work but I would prefer to use some thing like a red keyed operated one (eg: Airflow and need only on auxillary):
    https://www.sparesbox.com.au/part/ae...SABEgIQF_D_BwE
  10. The Following User Says Thank You to Bidja For This Useful Post:
  11. #8407
    Aug 2016
    Jimboomba
    4 Post(s)
    Thanks mate.
    Every car owners manual that I have read over the years actual says to charge the battery to help extend there lives.
    But yes it is always good to keep them topped up
  12. The Following 2 Users Say Thank You to Yeti's Beast For This Useful Post:
    Hodge (4th July 2018), jay see (3rd July 2018)
  13. #8408
    49 Post(s)
    Thanks fellas
    All taken onboard.
    I'm sure this will also help others too.
  14. #8409
    194 Post(s)
    Fitted new brake master cylinder, bleeding it on Saturday, hope it fixes the problem.
  15. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Bidja (7th July 2018), MB (6th July 2018)
  16. #8410
    Fitted this
  17. The Following 8 Users Say Thank You to rusty_nail For This Useful Post:
    Bidja (6th July 2018), Clunk (6th July 2018), Hodge (6th July 2018), Maxhead (7th July 2018), MB (6th July 2018), mudski (6th July 2018), PeeBee (6th July 2018), Rossco (6th July 2018)
