Results 1 to 10 of 16
Thread: Front Hub lock and 4wd questions
    Jan 2018
    I have manual front hub locks.
    - When I manually lock them. Its just locking wheel hub to Axel? Front Diff is still disengaged?
    -If I have them to lock Can I Shift into 4wd High while Im driving say on the beach at 40kms?
    -Say on fraser Island is it okay to keeps hubs locked and just go back to 2wd high if I go onto the resort which has sealed roads
    -On sand do I just have front hub locked and 4wd high or low. Leave e locker rear disengaged or should I have rear locked on as soon as I hit the sand too
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Yes you can do as you describe with hubs locked in no worries, except you can change into 4wd up to 80kph (with hubs locked)
    Still need to stop going to and from low in all conditions.
    You wont really need a locker for sand unless it gets soft, but id just run it anyway and turn off for bitumen (not much of that on Fraser)
  4. The Following User Says Thank You to 04OFF For This Useful Post:
    drgtr (16th March 2018)
    Jan 2018
    Thanks mate.
    So what happens if you try to change above 80kmhs? Just wont allow or does something break?
    With the lockers Id thought yeah If I turn and leave them on it will make going through the sand that tad easier with the soft sand inland tracks.
    Brisbane,QLD
    12 Post(s)
    Well ive selected from 2H into 4wd (hubs locked) doing 100kph and had no problem, its just that 80kph is the suggested max,
    But its just like ive done 60kph in low range and your not supposed to go that fast, but i think thats more to do with over speeding/heating the transfer case gears etc
    Just because ive done it no problem, does not mean its ok and that "you" wont have a problem
    Free Wheeling Hubs -
    You can leave them 'locked' from the day you drive out of the showroom if you want.
    In 'free' they just save a tad of fuel, a bit of tyre wear and reduce emissions a teensy bit.
    Indeed the Manual will say you should put them in 'lock' at regular intervals to keep the front end seals and diff lubed
    Many companies and government bodies will have SOP's for their 4X's that state the FWH's will be left 'locked' at all times unless the vehicle is to driven on bitumen for extended periods (1 I know of stipulates 300 kilometres).
    Diff Locks and Beaches/Dunes -
    Diff locks don't do all that much on soft sand it's all about tyre pressure.
    Sand usually provides equal albeit poor traction to all wheels.
    So 'locking' an axle to ensure power reaches the wheel/s with the best traction can, but not always, be of little effect.
    Locking the front diff (or locking both hubs if you have an auto locker) can actually make it worse on soft sand as the front may want to plough in on turns as the wheels cannot differentiate.
  8. The Following User Says Thank You to the evil twin For This Useful Post:
  9. #6
    Jan 2018
    Thanks guys
    SO on sand okay to stay in 2wd and go into 4wd when you need too or best to go into4wd?
    I came from a prado so always have the full time 4wd and just locked centre diff for 50/50 front and rear when I needed too.
  10. #7
    Brisbane,QLD
    12 Post(s)
    I have a Auto Locker in the front, and i find the car is actually better turning in soft sand, especially when turning out of the normal grooves or tracks used by everyone, you do have to adjust your driving style to suit having a Auto Locker, its only if you drive as if you still have a standard vehicle, it will it not steer well.
    If you are doing a well used track, such as most of the inland tracks on fraser, you can have deep holes much like wombat holes, a locker will certainly help here on the sand.
  11. #8
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by drgtr View Post
    Thanks guys
    Go into 4x4 and stay in it, no hero points for doing stuff in 2wd just because you "can", all you do is chew up the tracks for everyone else.
    Plus ive seen someone get stuck wrecking their car, up at Bribie Island, and all because he selected 2wd to drive on the hard sand, but forgot to put his car into 4x4 before doing a water crossing, it ended bad for him.
  12. The Following 2 Users Say Thank You to 04OFF For This Useful Post:
    4bye4 (16th March 2018), drgtr (16th March 2018)
  13. #9
    Jan 2018
    Quote Originally Posted by 04OFF View Post
    thanks.
    No detriment to the locker itself if I have the locker on all the time in the sand?
  14. #10
    Brisbane,QLD
    12 Post(s)
    thanks.
    Yeh no drama, sand will offer little resistance to a rear locker, less strain on it than driving dirt or rocks etc.
  15. The Following User Says Thank You to 04OFF For This Useful Post:
