30th May 2019, 11:55 PM
I'm running the original Bridgestone DD's and the factory alloy rims. Loads of meat left on them. So are you guys saying that the new radius arm bushes (nylon I think they are now), are rubbish? I just looked up and saw the price of new radius arms ... aaarrrgggghhhhh nope wont be going down that path. So if I'm doing anything it will have to be bushes. Which brand I dont know ...
30th May 2019 11:55 PM
31st May 2019, 12:17 AM
Moderator
timbo2410
yes unfortunately the Nylon bushes by design are harder than rubber so dont flex as well. also with the offset they tend to chew out. You might get 5 years out fo them but likely 1 or 2. If i was you id be fitting offset bushes to sort it out. 100%
Check out my Toy -->
Rogue Dung Beetle
31st May 2019, 12:19 AM
Moderator
What i would Actually do is buy new springs and go to a 3" lift allowing you to fit Drop Boxes and never look back. This is Illegal though..... But its bloody Perfect.
Rogue Dung Beetle
31st May 2019, 12:21 AM
Moderator
MB
Your beast needs to go in mate if it’s “Traming” suspecting that means running out of carish tarmac lines?
Which tyres you running good bloke ?
Yeah it will be Oversteering like a Boss. Check your Tyre Pressures, make sure they are all correct.
Rogue Dung Beetle
31st May 2019, 12:22 AM
Way out of my league now Timbo mate! Do know that on our ageing little fleet of trols, OEM rubber does seem to last best as kindly suggested!
31st May 2019, 12:52 AM
No no I only assumed that a rubber substitute was better .. If I am wrong I stand corrected. I'm struggling to find any sort of "kit" as suggested by the mechanic today. I might pay a visit to our local Pedders and see what they have to say. Also, Tyrepower were the sub contractors to Ironman fitters. They were the ones who did all the aligning .. I might go in and ask for the angles and measurements so at least I can post here for advice.
The Following User Says Thank You to timbo2410 For This Useful Post:
MudRunnerTD (31st May 2019)
31st May 2019, 02:19 AM
#17
and yes tyre pressures have been checked .. have also run anywhere from 32 up to 42 psi to see if it makes a difference .. and no it doesnt ..
31st May 2019, 10:09 AM
#18
Moderator
timbo2410
Rubber is best but the caster correction bushes are all nylon. you should really only need a slight adjustment? 2 degrees or so. Get your measurements and ask them how "Out" it was. They should be able to tell you the factory tollerance.
Rogue Dung Beetle
31st May 2019, 11:40 AM
#19
ok i will shoot into town this afternoon and ask tyrepower if they still have the specs or at least get them to check the specs .. I will post back asap
31st May 2019, 04:32 PM
#20
just an update, Tyrepower do have the specs from the original alignment (front and rear) and will re-check them next Tuesday morning. He did explain that yes the only way to correct the issue may be the castor kit as he checked the tyres and said there is no extra wear that bad now that would cause the tramming to be that bad. He did advise to get the correction kit from ARB or Opposite Lock here in town and not to go to the local Ironman centre though. So will post back here on Monday. Thanks for the help thus far people :-)
