30th August 2018, 08:59 AM
#111
Best place to buy Warn Hi mount parts?
Scary hey, but awesome in the end mate!
EDIT: And round two....playing around with high output alternators gets exy real quick also but your Mahle motor beast will love you for it if we can stop the alts cooking diodies :-)
30th August 2018 08:59 AM
12th October 2018, 11:28 AM
#112
No point rebuilding.
Buy the whole thing soon.
The Following 3 Users Say Thank You to Hodge For This Useful Post:
MB (12th October 2018), MudRunnerTD (13th October 2018), mudski (12th October 2018)
12th October 2018, 12:44 PM
#113
Have they just copied Gigglepin with the upgrades maybe?
As for my hi mount build. Its just sitting here in pieces at the moment. No time to scratch myself lately.
12th October 2018, 01:26 PM
#114
mudski
I have no idea Marko, nor do I have any clue about high mounts...
That's just what I saw on Facceache and screengrabbed it.
The Following User Says Thank You to Hodge For This Useful Post:
12th October 2018, 06:59 PM
#115
Hodge
Without looking more into it I reckon the new version will be along the lines of the GP upgrades. It would be interesting to know if the upgraded parts for the new model can be shoe horned into the older model.
12th October 2018, 07:24 PM
#116
The 747
mudski
I reckon it's just a new motor.
12th October 2018, 09:41 PM
#117
Half cut here Friday, anyone able to kindly find and post up a new speccy sheet for our waffle making freshy hopefully the bees knees?
13th October 2018, 04:38 AM
#118
MB
WTF are you talking about MB? 'waffle making freshy'?
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
MB (14th October 2018), MudRunnerTD (13th October 2018), Rossco (13th October 2018)
13th October 2018, 04:49 AM
#119
Winnie
I agree. If they are doing it from scratch, which they are not, they would look to match the same duty factor of the gears to the pull/motor HP. Since the casing looks the same, the gear ratio and the gear set will be the same, now putting more HP thru the same tooth module = lower FOS and lower duty rate. Not my way of engineering a drive train, but I guess for the amount of time these units typically get used in reality , the extra tooth wear is negligible. I guess others have been running higher HP thru these same gear sets for ages, so in some regards my comments are moot. No doubt Warn have done the numbers as they have to warranty them as well. So for me, the upgrade is heading in the wrong direction, so I would not buy one, and for the record i have had 2 of the High mounts on previous vehicles, didn't rate them, but they were 'standard' units, not with GP and motor upgrades.
13th October 2018, 05:04 PM
#120
Moderator
Winnie
Nah looks like the Brake Shaft is Tapped and Capped and there is something on the top housing that i cant make out. If it is faster then it likley has a +40% Mainm Gear in it too which would give it the upsec wieght rating too. A bearing end plate would be a nice addition too.
Check out my Toy -->
Rogue Dung Beetle
