Page 7 of 18 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 172
Thread: Back in a GQ
  1. #61
    Dec 2012
    Work
    How user friendly is the top shelf? Looks pretty tight?
    I can fit my little fishing (sidekick) chair up top and some jackets, so will suit my needs
    Just another Blue over Silver GQ with another TD conversion
    I've got a fully enclosed one in mine.... Got a couple of those square aluminium tables up there. 3 small camp chairs for the kids, Jump leads. 2 sets of led light strips amd a few other things. Could also get into it from the back seat side but cargo barrier is in the way of it...... Works well. Will take a photo when I get the chance or if I remember.
    Apologies for the hijack Dave
  4. The Following User Says Thank You to Clunk For This Useful Post:
    Reddave (25th November 2018)
  5. #63
    Dec 2012
    Work
    All good Clunk, be interested to see the photo of yours, you never know how much you can fit somewhere till you see someone else’s setup!
  6. #64
    193 Post(s)
    Thanks guys, I have had a top shelf unit in a couple of 4wd's over time, and in the GQ but have removed it when changing the back around - curious to gauge access as might re-install it for the lighter stuff, and coming in from the back seat, never thought of that, as the cargo barrier is in the way.
  7. #65
    Dec 2012
    Work
    Made up a switch panel for lights and a battery voltage monitor, just need to wire it up now
  8. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    MB (4th December 2018), MB TD42 (14th January 2019), PeeBee (3rd December 2018)
  9. #66
    Dec 2012
    Work
    Went on a bit of a spending spree:
    Brought a high mount off Facebook marketplace, it’s in pretty bad shape but the main bits are there, nothing a rebuild and some new parts can’t fix
    So stripped it down to nothing, it’s off to get sandblasted later in the week, then next year I’ll start the rebuild
    Brought a UFI fan and hub, this should keep it cool when I give it some more fuel and got the A/c on flat out
    And my 18G turned up today, I’ll be running it on my 11mm pump until next year when I buy a 12mm pump and get it tuned, this should wake it up enough for now
  10. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    MB TD42 (14th January 2019), PeeBee (17th December 2018), rusty_nail (23rd January 2019)
  11. #67
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Niiice🤤🤤🤤🤤
  12. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    Reddave (21st December 2018)
  13. #68
    Dec 2012
    Work
    Got my high mount stuff back from the sandblaster this morning, ordered a brace kit to be welded on when I start putting it back together
    Fitted my UFI fan and hub and took the car to my Mum and Dads for Christmas, had to roll start it to get home so now I need a new starter motor
    Better to happen now than in the bush I suppose
  14. The Following 2 Users Say Thank You to Reddave For This Useful Post:
    MB (22nd December 2018), MB TD42 (14th January 2019)
  15. #69
    472 Post(s)
    Back in a GQ
    Rock on RD mate, you’re a serious mover and shaker good bloke!
    Only my opinion but reckon our Warn HM’s look and greasy stay timeless with a good ‘black/charcoal’ powder coat atop
    Tends to blend in a bit better too with dark grills for candy cars forthcoming afront looking for that extra excuse to tail back
    EDIT: Paying it forward here RD mate, best to contact ‘Phil’ at the ‘4WD Shed’ and book in a ‘Iskra/Mahle’ 6hp motor! @MudRunnerTD top advice for me and never looked back for sure! (Cheaper than others back then too )
  16. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (24th December 2018), Reddave (23rd December 2018)
  17. #70
    Dec 2012
    Work
    Thanks mate, looking into bits and pieces and Phil is just down the road from my work, I’ll wait till they get back in the new year!
    Started doing my turbo upgrade, so the old one had to come off
    The size difference between these two is massive, I’m teally looking forward to driving it!
    Got it back in
    Still a fair bit to do, managed to keep the factory heat shield. Unfortunately I’ve damaged the fitting that goes into the block for the oil drain so need to source a new one of those, redo my cooler piping and do the intake, set up wastegate, lengthen my dump pipe
  18. The Following 4 Users Say Thank You to Reddave For This Useful Post:
    JackoGQYoot (30th December 2018), MB (9th January 2019), MB TD42 (14th January 2019), PeeBee (30th December 2018)
