Results 1 to 10 of 27
Thread: 2001 gu2 zd30 boost nightmare
Threaded View
    Jan 2017
    Apologies for the delay. Work commitments.
    Purchased a Vac tester and the ECU Talk cable was delivered.
    Vacuum Testing Results: with Needle valve completely closed
    T added Piece before VNT actuator = 12"Hg
    VNT actuator receiving = 28"Hg
    ECU Results:
    BTW, DI has a consult comms port not OBD2.
    This is the plug i have on the patrol. (PIC)
    The ECU Talk cable I got was able to give me the following codes using my laptop.
    Code 73: P3-Pump Comm Line
    Code 95: Turbo Pressure
    Cleared the codes but no change.
    Is my next step disconnecting the VNT actuator rod to see if rod moves freely? I have attached a pic of the VNT actuator at idle, still not touching the stop screw
    Do i need to check vanes now to see if theyre clogged?
