Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: URGENT HELP PLEASE - How to drain reserve tank
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Hi all,
    Ok what is the quickest and easiest way to drain the reserve tank?
    Does it have a bung or do I need to undo the transfer hose?
    I’ll be back online line in about an hour.
    Jack
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Hi all,
    Just had a look at mine - doesn't appear to be adrian plug on either tank. but mine is an earlier model. What happened?
  4. The Following User Says Thank You to 4bye4 For This Useful Post:
    jack (22nd February 2018)
    Ballarat Area
    25 Post(s)
    16 litres of contaminated fuel (petrol), in there. Hasn’t been started and home on a tilt tray.
    Jack
    Aug 2014
    Kingsley WA
    15 Post(s)
    If its just petrol, you could siphon as much as possible out, then fill with diesel. Also fill the main with diesel. Then start the car and as you use up fuel put a little from the res into the main and top up the res. A little petrol in the diesel will not hurt the motor and doing it this way should really dilute it. Just top up with diesel as often as possible for a while and it will be OK.
  7. The Following 3 Users Say Thank You to 4bye4 For This Useful Post:
    AB (22nd February 2018), GQtdauto (22nd February 2018), jack (22nd February 2018)
  8. #5
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I agree with 4by4 , if your reserve tank has just been topped up with 16 litres it's about a 50-50 mix now so just do as above but make sure reserve is filled with diesel if you haven't already topped it up.
  9. The Following User Says Thank You to GQtdauto For This Useful Post:
  10. #6
    Ballarat Area
    25 Post(s)
    Thanks for the responses, will have a look on Saturday and empty the tank. Being a CRD not game to try diluting the mixture.
    Jack
  11. #7
    May 2016
    8 Post(s)
    Yes I pulled y tank out . Or take the fuel tank gauge. That gives you access . To mop itout
  12. The Following User Says Thank You to Tip12345 For This Useful Post:
  13. #8
    hey mate i'll ring me mate at Nissan tomorrow n get back to you with an anwswer,why not do what ya said,undo pipe and hit the button,pump it out?main tank has to be below 3/4's
  14. The Following 2 Users Say Thank You to Avo For This Useful Post:
    jack (22nd February 2018), MB (22nd February 2018)
  15. #9
    Ballarat Area
    25 Post(s)
    Where is the fuel transfer pump located? I've only had a quick look as the car is outsize and the weather here has been crap.
    Jack
  16. #10
    I wouldn't have a clue mate,,i can ask that to..have you downloaded the manual yet,surely it'd have most info there..donm't worry I should download it to
  17. The Following User Says Thank You to Avo For This Useful Post:
