Results 21 to 30 of 32
Thread: Whats best
    On powerlines we use 95mm2 as bare minium for 200A circuits, for wiring up transformers secondary voltage. Anything up to 185mm2 feeding 400A circuits. DC is probably different. And I'm sure there is also different grades of copper is there not.
    Dc is different mate. Usually the lower the voltage the higher the current needs to be.
    I would have cursed the engineer for that shit.
    Underground supply to a shed with a small pump.
    From memory it was about 800m
  4. #23
    22 Post(s)
    Thats with everything.
    96 GQ coil/Cab
    08 G6eT
  5. #24
    22 Post(s)
    Yeah, with a subboard is alright.... It's when you're expected to terminate it into the gpo....... I have been there
    96 GQ coil/Cab
    08 G6eT
  6. #25
    Ah, no, that was not expected lmao
  7. #26
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Not the best Piccies sorry. But I have my high mount hard wired in. The solenoid is a full waterproof jobbie, currently mounted behind the bullbar. (Plans to move it somewhere more out of the elements.
    I have the two switches, mostly in case I accidentally bump it while going for the reversing lights.
    Cheers.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  8. The Following User Says Thank You to Punderhead For This Useful Post:
    Sir Roofy (25th May 2016)
  9. #27
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    These are mine. In/out toggle with isolator switch next to it. Left hand side of steering wheel.
  10. The Following User Says Thank You to sooty_10 For This Useful Post:
  11. #28
    109 Post(s)
    That makes sense then. I was about to call BS!
  12. #29
    462 Post(s)
    This is something i need to do. But the wired hand controller on mine has four wires in it. All others ive seen have three.
    Unless its different in the winch control box....
  13. #30
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    We'll open mine over the w/end and have a look see
