Results 11 to 20 of 48
Thread: Gu cruise control
    Advanced Dannyboyz's Avatar
    Jan 2016
    Thanks Kallan, might be a good time to get the AC idle up working, it was one thing that didn't get hooked up when I swapped out the 2.8 for the TD42
  2. The Following User Says Thank You to Dannyboyz For This Useful Post:
    BigRAWesty (30th May 2016)
    I have the Autron CC find it very easy to use, only thing Ive changed is the led light position
    for when its on from down on the dash in front of the tacho to next to my gauge on the
    pillar pod. Much easier to read from there imo
  5. #13
    Jan 2016
    Thanks TD, My brother has that kit in his GU and he was saying it's hard to see that light down near the keys, I will show him that photo, looks neat mate. I love the steering wheel controls. I wish that my Command kit had those controls
  6. #14
    Quote Originally Posted by Dannyboyz View Post
    It was easy enough to extend the existing wiring , solder and heat shrink
    on all three wires, I blocked the old hole with a black moulding plug
  7. #15
    Jan 2016
    I like it TD, much neater than I would have done, lol, on another note, does anyone have any other ideas on where to get my vacuum from? I now remember why I didn't hook the AC idle up, the 2.8 didn't have the vacuum idle up, it was electronic I belive, so unfortunately I can't use that as Kallan suggested so I am now on the hunt for another good vacuum source!
  8. #16
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Not sure how your conversion way done but I have the idle up vacuum valve and lines in mine. It just doesn't do anything for idle, but i could easily use it as a vacuum source.
  9. #17
    Dec 2015
    WA
    5 Post(s)
    Is there a vacuum tank?
    Follow the hoses to/from the tank.
    Graham
  10. #18
    43 Post(s)
    The TD should have one but being a conversion it may have not been fitted..
    The later ZD30 doesn't have em but my old GQ definitely did need it..
    May 2016
    Quote Originally Posted by GeeYou8 View Post
    I don't remember the model, but they did make one for the ZD30 (GU2) that uses speedo pulses & electronic throttle control so there is no mechanical cable.
    When I enquired it had to be installed by a Command Auto dealer.
    Graham
    See below.
    The Cruise Control units for the ZD30 (drive-by-wire) were originally known as Auscruise before Autron.
    http://www.autron.com.au/pages/Auscr...ve-by-Wire.php
    I used to be an qualified CC installer years back and these were great at keeping exact speed without chasing that comes with vac controlled setups.
    The units were not for DIY as it required factory loom and plug pins to be pulled and modified. Afterwards, you have a smooth controller.
    The "D-shaped" controller can be seen in the images below:
    http://www.autron.com.au/pages/Image...ery/Images.php
    There is no legal cure for STUPID!
  12. #20
    Jan 2016
    @ sooty and westy, I do have the actuator for the idle up on the motor under the throttle, it pulls on the same bit as the throttle cable, however there is no valve or lines on the body to hook it up. Westy I did find the speed sensor and have connected to it, so thank you for that.
    @ Geeyou I do have the two black vacuum tanks on the passenger side of the engine bay, between the second battery and the firewall. One is bigger than the other and they are joined on the top by a couple of large hoses (approx 3/8) would it be possible to T into one of these hoses? Or should I chase the hoses to somewhere else?
    @ lostbenji, that would explain why I couldn't find a DIY kit with the D shaped controller when I was chasing one, lol, so thanks for the info
