Results 1 to 10 of 10
Thread: Screeching from rear drivers wheel when turning left
    Advanced Sofes's Avatar
    Jan 2018
    Radelaide
    So, bit of a back story. I went to my mates shack and he conned me into going through the clay fields (my first time ever off-road).
    Got bogged, and clay was everywhere in the drivers side wheels (along with the shell grit and everything)
    Cleaned it out once I got back, took the wheels off and everything, got into the rear wheels, brake pads and everything.
    Shortly after I put the wheels back on I noticed the squealing/screeching from what I can assume is the rear drivers side wheel when turning left and any speed.
    Took the wheel off and inspected it and nothing was out of the ordinary.
    My first thought was brakes but it still occurs even if I'm not braking.
    Anyone experienced this or can off a fix?
    Can provide more details if necessary.
    Cheers!
    Are the disc backing plates still attached, if so, something may or may not be stuck between plate and disc
  4. The Following User Says Thank You to Clunk For This Useful Post:
    the evil twin (30th January 2018)
    Intermittent squealing when turning is also symptomatic of a dodgy rear wheel bearing...
    Clunk (30th January 2018)
  7. #4
    201 Post(s)
    Yeah I'd start with rear wheel bearings too. Mine used to squeal on deceleration.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #5
    80 Post(s)
    Check that the pinion nut on the diff is at the correct torque, as it can also try and lock the wheel when turning. Although the sound appeared only when I turned hard to the right.
  10. #6
    Jul 2015
    Camden NSW
    6 Post(s)
    It could also be an indicator for a rear diff lock being left engaged, semi-colapsed LSD plates, wheel bearings, or diff bearings.
  11. #7
    Jan 2018
    Radelaide
    Thankyou for the responses guys, I'm no home mechanic so still learning but Ill be checking all.
    I was thinking that, considering it only occurred after I had power washed the clay and shell grit after taking the wheel off.
    Just got to figure out how to take it off and check.
  12. #8
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    Post
    4.8s often squeal from the back wheels/tires. It's a Fitek thing
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  13. #9
    Jan 2018
    Radelaide
    Quote Originally Posted by Bulbous View Post
    Haha I get that.
    I'm just not sure whether I'm causing any damage to my car or not. Hasn't affected anything as of yet (touch wood).
  14. #10
    Legendary dom14's Avatar
    38 Post(s)
    Yep, the most common reason when backing plates are in place.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
