11th July 2016, 07:06 PM
#11
Rotaredom
Thread bump 4 4bee as his post went into moderation
@macca
11th July 2016 07:06 PM
11th July 2016, 09:57 PM
#12
Enjoying the trips
4Bee
Hi Macca . . . waaaaayyyyy old thread, but if you can cast your mind back, was the Speedflow adaptor you bought a 12mm 1.25 pitch to go into that hole on the thermostat housing? or did you have to drill and tap it?
Thanks mate
Simon
Sorry mate just got the notification to let me know there had been a quoted reply.
As for your question I have no idea, unfortunately the part that came out is buried in the Trol ready for an extended trip. Carry it as a repair if the sender fails / leaks.
Think @Cuppa did something like this so he might be able to help.
Macca
12th July 2016, 08:13 AM
#13
Travelling Podologist
Hi, yes I copied Macca with the Speedflow adaptor. It screwed straight in with no need for any drilling & tapping. Easy & convenient. It was 12.mm x 1.5 pitch. See pic below for part no. In normal use my coolant temp reads 80 degrees, rising to 90 degrees in hotter weather & under load.
The Following User Says Thank You to Cuppa For This Useful Post:
12th August 2016, 02:29 PM
#14
Thanks Macca & Cuppa,
I did eventually get one of those same adaptors, but had to run a tap through the hole to get it to screw in . . .
All good though, its working like a champion now
I see my previous post went into moderation? what's that all about?
thanks again
Simon
3rd September 2016, 08:32 AM
#15
Cuppa
Cuppa, is that adaptor with the redarc 1/8" temperature sender? Fit ok? Does the probe stick out of adaptor far enough to reach coolant?
3rd September 2016, 02:06 PM
#16
Rip'n'Shred
Hi Rip, Yes it's with the redarc sender. Fitted & works perfectly.
Rip'n'Shred (3rd September 2016)
