Page 992 of 1049 FirstFirst ... 49289294298299099199299399410021042 ... LastLast
Results 9,911 to 9,920 of 10488
  1. #9911
    192 Post(s)
    Finally managed to get my spare tyre out, 1psi and all
    Look'n good Markie, looks like she's blow'n a bit of black smoke in this pic tho.
    Not wanting to give you another task but might be worth checking the rubber boot ontop of gearbox around lever, I know mine needs replacing already isn't that old. . .
  2. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    10G (15th February 2021), MB (14th February 2021)
    472 Post(s)
    Will do, thanks Legend
    Rossco (14th February 2021)
  6. #9913
    Jun 2018
    24 Post(s)
    Put half a shed junk checker plate box to use as a heat shield from the pissy little Safari turbo:
    Baby compressor and new catch can fitted up pretty well:
    Will have to play around a bit more with hosing for both contraptions during the week before taking the plunge into drilling holes through the new airbox
    Pretty happy with the catch can drain, should be able to rest a little empty Berocca bottle on the coil tower whilst waiting:
    Good to see someone else running the flashlube catch can. A good bit of kit and compact size makes mounting easy
  7. The Following User Says Thank You to Cremulator For This Useful Post:
  8. #9914
    472 Post(s)
    Truth be known Cremulator Mate!
    Was watching Youtubey on their 230Lm rating and apparently suitable for V8 Landcrabs of 120Lm and then instantly your awesome post kindly popped up on another thread suggesting of their shorter/compact size which I felt needed for this build too.
    Youtubey research does appear the Provent 200 is the Bee’s Knees for big HP/Kw donks but I’m only currently running 70rwkw
  9. The Following 2 Users Say Thank You to MB For This Useful Post:
    10G (15th February 2021), Cremulator (15th February 2021)
  10. #9915
    472 Post(s)
    FWIW too Cremulator Mate!
    The big industrial Pro-200’s have 25mm inlet/outlets that need to reduce down to our TD42 little 12mm OEM rocker cover venty thingies. The Flashlube being a 19mm down to 12mm upon reading fittings required nuffy seemed a lot more suitable donk sized to me too
  11. The Following 2 Users Say Thank You to MB For This Useful Post:
  12. #9916
    May 2016
    lower west victoria
    30 Post(s)
    hahahaha, classic MB, did you pump it up in place???
  13. The Following User Says Thank You to 10G For This Useful Post:
    MB (15th February 2021)
  14. #9917
    472 Post(s)
    Nah I deflated it to 1psi then foolishly pushed it in with the Kanga loader from work
  15. The Following 4 Users Say Thank You to MB For This Useful Post:
    Cremulator (15th February 2021), jack (15th February 2021), MudRunnerTD (15th February 2021), Rossco (15th February 2021)
  16. #9918
    May 2016
    lower west victoria
    30 Post(s)
    hahahahaha, ^^^ you're a mad bastard
  17. The Following User Says Thank You to 10G For This Useful Post:
  18. #9919
    330 Post(s)
    Bhahahahaha. It worked great at the time. You clearly gave it Zero thought for coming back out again on a Steep Track in the High Country...
    A Safety blanket would have made that pic all the more better brother.
  19. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  20. #9920
    472 Post(s)
    It’s been stuck in there since early 2020 from working out the back of Bourke, heaps of trees to tie to out there and gun it
  21. The Following User Says Thank You to MB For This Useful Post:
